871 Initial Configuration
rspears20011
Haven't used router commands in years, so I thought this would be a lot easier in SDM. Rustier than I thought!! Need to create an internal vlan (192.168.1.0) and NAT WAN fe04 with ip that corporate has given us to use (45.245.13.21) to connect to corporate router (45.245.13.20). Need to have internal users on 192.168.0.1 go through 192.168.1.0 vlan connect to corporate 45.245.13.20. Suggestions??  Thanks!!!
Reza Sharifi
Here is the config guide you can start with.  There are examples on how to configure the interfaces with IP, host name , username, password , etc...
http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
Reza
