877 DNS problems
A cisco noob here. At home I have a small test lab with a 877, this 877 is connectect with the fa0 to my service provider router. I want to configure a DNS server, but when I do I can ping to a DNS name from my 877 but nog from my client. I hope some of you cisco gurus can help me out?
Here is a sh run and screenshots of the ping commando. (ps. I did enter de commando ip domain lookup)
version 12.4
no service pad
hostname Geoffrey_Home
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.10
ip dhcp excluded-address 10.0.0.200 10.0.0.254
ip dhcp pool NETWORK_10.0.0.0
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.254
   dns-server 10.0.0.254
ip host router 10.0.0.254
ip host laptop 10.0.0.11
ip name-server 8.8.8.8
username geoffrey privilege 15 secret 5 $1$m2LO$kd/uNJ6UjvMqVtE4RkIpx0
archive
log config
  hidekeys
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
switchport access vlan 50
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan50
ip address 192.168.2.200 255.255.255.0
ip nat outside
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.2.254
ip dns server
no ip http server
no ip http secure-server
ip nat inside source list 101 interface Vlan50 overload
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport preferred none
transport input ssh
transport output none
scheduler max-task-time 5000
end
Translation of the text after the ping request: Ping-request cant find host laptop. Check the name and try again.
Hello Geoffrey
That because as stated previously the ip host command is locally significant to the router so it will be able to ping the client however this will not be propagated outside that router
Res
Paul
Kind Regards
Paul
24 Replies 24
alam
Community Member
Please confirm your PC is using your router as DNS server. How about another record (e.g. router)?
Yes it is... and the other record doesnt work also. thats whats weird about it...
excusse me... the other record work the same as this one...;)
Bilal Nawaz
Hello, I can see that you have a host entry in the router
This is almost like adding an entry in to the 'hosts' file on a PC. (its static)
The router is not using DNS in its true sense. If you was to remove that command, it probably wont work, but try it to make sure.
Im not really sure on how to achieve this in ios. But you could just edit the host file on your PC. But obviously this isn't the solution you are looking for.
This might be able to help:
https://learningnetwork.cisco.com/servlet/JiveServlet/previewBody/6248-102-1-20340/DNS%20Configuration%20of%20Cisco%20Router%20as%20DNS%20Server.pdf
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
thanks.... but like you said, this isnt the way i'm looking for.... just want to make this work to practice for CCNA.
Hello
I am assuming your dhcp clients are receiving a dhcp address and can ping 8.8.8.8?
if so in your dhcp pool specify your isp dns server addresss instead if the default-gateway
also if you are using hosts file on the client then dont!
one you have ammended the dhcp pool clear the dns from the clients
ipconfig / release
ipconfig / renew
ipconfig / registerdns
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Hello Paul, Will this resolve local hostnames too?
e.g. laptop is able to ping "router" and "laptop"
Paul, thanks for the reply... but i already did this, this router already has been reboted (i did wr before reboot;))
for my knowledge i did everything right... If i do the ipconfig /all i see that my DNS realy is 10.0.0.254... for the info... the laptop from where i send this ping from is not the laptop with IP 10.0.0.11 ..... it is like the DNS works fine with in the router... but doesnt send his information correctlie to the client... I have already spend google-ing for hours with out result....:S
Hellp bilal
to be honest mate in this setup not sure it will
usually i would have an internal dns/wins server to point to if i wanted to acces my internal routers by name.
if you do want the clients to ping this router by then wihout creating a dns/wins server the only option is static hosts file on the cleints
res
paul
Kind Regards
Paul
hello geoffrey
are you saying changing the dns server address in your dhcp pool isnt being propergated to the clients
forgive me but would you clarify what is your ultimate goal you would like to acheive?
fyi - ip host x command is ONLY local significant ias far as i am aware t will not be propergated to clients via dhcp
res
paul
Kind Regards
Paul
My situation is as following:
Router: 10.0.0.254 (used as DNS)
Client A: 10.0.0.11 (in this case a laptop)
Client B: 10.0.0.12 (in this case a laptop)
My goal is to reach client A from client B by using a DNS.
My practical goal is, when you have a IP phone with default FTP server/pbx adress XXX.XXX.local or something like that, I dont need to to change this manual any more.
But i wanne focus on my goal to reach client A, from client B, by using a DNS. before i go a step further.
Hello Geoffrey
thanks for the clarification - i would suggest you then use a specific server to perform the dhcp and dns functions instead if a cisco device although you can run dhcp/dns services there main job is route/switch traffic and adding these serivces like dhcp/dns requires the router/switch to alocate cpu/ memory towards them.
The benefit of say Windows server doing the job is:
dns/dhcp and client intergration with or without active directory
more manageable
less resource requests on the router/switch to run these service
and last but no least resiliency of these services through primary and secondary servers
hope this helps
res
paul
Kind Regards
Paul
I will take this into consideration but some times this is not possible. Also i still think its a little but strange that is can ping the DSN name from out the 877 and not from the client... I know its a little bit stubborn of me... but I just want to have it work... so I know it can;)
What DNS name are you pinging -The router itself from the router?
Res
Paul
Kind Regards
Paul
