877W Unstable LAN random disconnects
xwBAKo3wYKK1o
Hi everyone!
Currently I am studying for my CCENT. I have used a 877W as my lab router to replace my ISP modem/router.
The wireless, LAN, and DSL dialer seems to work fine, but the LAN disconnects randomly about every 10 hours for IOS 15.1, and for IOS 12.4 the DSL dialer desyncs every 2 days.
Not sure if this applicable, few days ago I opened SSH version 2 port over the internet, and someone in Beijing China (according to #terminal monitor) attempt to access the SSH using usernames like, root/admin/ubt etc, lucky I use 13 char long randomized username and passwords. So I did a counter port scan on the attacker, so he stopped his/her dictionary attack against my SSH, but after doing an SSH version check. (according to #show ssh) After how quickly attackers attempt to "break-in" I have blocked it with an ACL currently.
Here are some config information:
Connection Version Mode Encryption  Hmac         State                 Username
0          2.0     IN   aes256-cbc  hmac-sha1    Session started       xxxxxxxxxxxxxxxxxxx
0          2.0     OUT  aes256-cbc  hmac-sha1    Session started      xxxxxxxxxxxxxxxxxx
Building configuration...
Current configuration : 4034 bytes
! Last configuration change at 23:05:20 EST Sun Sep 13 2015 by xxxxxxxxxxxxxxxxxxx
version 15.1
no service pad
service password-encryption
hostname 31AUG2015CCNA
boot-start-marker
boot system flash c870-advsecurityk9-mz.151-1.T5.bin
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone EST -5
clock summer-time EST recurring
dot11 syslog
dot11 ssid RSGE_Cisco
 vlan 1
 authentication open
 authentication key-management wpa
 guest-mode
 wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip source-route
ip dhcp excluded-address 222.222.222.1
ip dhcp pool dhcppool
   network 222.222.222.0 255.255.255.0
   default-router 222.222.222.1
   dns-server 107.170.95.180 104.237.144.172
ip cef
ip inspect name FW udp
ip inspect name FW tcp
ip inspect name FW ftp
ip inspect name FW icmp
ip inspect name FW http
ip domain name xxxxxxxxxxxxxx.org
ip name-server 107.170.95.180
ip name-server 104.237.144.172
ip ddns update method noip_update
 HTTP
  add http://zPodNS7mexmKm:xxxxxxxxxxxxxxxxxxxx@dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
  remove http://zPodNS7mexmKm:xxxxxxxxxxxxxxxxxxxx@dynupdate.no-ip.com/nic/update?hostname=vpn&myip=rsge.org
 interval maximum 0 0 5 0
 interval minimum 0 0 2 0
login block-for 65535 attempts 2 within 65535
login on-failure log
login on-success log
vpdn enable
vpdn-group pppoe
archive
 log config
  hidekeys
username xxxxxxxxxxxxxxxxxx secret 5 xxxxxxxxxxxxxxxxxxxxxx
ip ssh version 2
bridge irb
interface ATM0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no atm ilmi-keepalive
 pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
 no ip address
 encryption vlan 1 mode ciphers aes-ccm
 ssid RSGE_Cisco
 speed basic-2.0
 channel 2417
 station-role root
 world-mode dot11d country US outdoor
 no cdp enable
interface Dot11Radio0.1
 bandwidth receive 400
 encapsulation dot1Q 1 native
 ip virtual-reassembly
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Vlan1
 no ip address
 ip inspect FW in
 bridge-group 1
interface Dialer1
 ip ddns update hostname vpn.xxxxxxxxxxxxxxx.org
 ip ddns update noip_update
 ip address negotiated previous
 ip access-group WAN_FIREWALL in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 ppp authentication chap callin
 ppp chap hostname vzxxxxxx
 ppp chap password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
 ppp pap sent-username testtest1 password 7 xxxxxxxxxxxxxxxxxxxxxxx
 no cdp enable
interface BVI1
 ip address 222.222.222.1 255.0.0.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat pool natpool 222.222.222.2 222.222.222.240 netmask 255.0.0.0
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended WAN_FIREWALL
 deny   icmp any any
 permit ip any any
access-list 1 permit 222.222.222.0 0.0.0.255
access-list 1 deny   any
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^C
Unauthorized access may subject to
criminal prosecution
                 -RSGE
*************************************^C
line con 0
 exec-timeout 600 0
 password 7 xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
 logging synchronous
 login
 no modem enable
line aux 0
line vty 0 4
 access-class 1 in
 exec-timeout 600 0
 logging synchronous
 login local
 transport preferred none
 transport input ssh
 transport output none
scheduler max-task-time 5000
ntp server time.nist.gov
end
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'BDCM'
Chip Vendor Specific:  0x0000                    0x544D
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          '    '
Modem Vendor Specific: 0x0000                    0x0000
Modem Vendor Country:  0xB5                      0x00
Serial Number Near:    FHK12482BF2
Serial Number Far:
Modem VerChip ID:        C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   45%                             85%
Noise Margin:     9.5 dB                         11.0 dB
Output Power:    16.0 dBm                        12.0 dBm
Attenuation:     55.0 dB                         33.0 dB
FEC ES Errors:    0                              2268
ES Errors:        1                              223
SES Errors:       1                               4
LOSES Errors:     1                               4
UES Errors:       0                              3922
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0xFA
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      4202 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR_6.0.010.bin
Operation FW:    AMR-E-6.0.010.bin
FW Source:       external
FW Version:      6.0.10
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             2528             0               861
Cells:                    0        614220628             0         286460339
Reed-Solomon EC:          0             2294             0             15114
CRC Errors:               0                6             0               270
Header Errors:            0                5             0               941
Total BER:                0E-0           6259E-11
Leakage Average BER:      0E-0           1390E-10
Interleave Delay:         0               43             0                63
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 7 9 9 A B B C C C
010: C C C C C C B B B B B B B A A 9
020: 0 2 3 4 5 6 7 7 8 8 8 9 9 9 8 8
030: 9 A A A A A A A A A A A A A 7 A
040: 9 A A A 9 9 9 8 8 9 8 A 2 7 7 9
050: 9 8 9 9 9 9 8 8 8 7 6 7 8 6 8 8
060: 7 7 7 7 7 7 7 7 7 7 7 6 3 4 6 5
070: 6 6 6 5 5 5 5 5 5 5 5 5 2 5 5 5
080: 4 3 4 4 2 2 0 0 2 2 2 0 2 2 0 0
090: 0 0 2 2 0 2 2 2 0 0 0 0 2 2 2 2
0A0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
100: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
110: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
120: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
130: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
140: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
150: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
160: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
170: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
180: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
190: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1A0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
xwBAKo3wYKK1o
Sep 14 16:41:36.794: %DOT11-4-MAXRETRIES: Packet to client c81e.e785.e453 reached max retries, removing the client
I think it might be MTU size, not 100% sure.
