Highlighted
Beginner
887VAW - WLAN to wired routing
I am at a relatively basic level when it come to cisco routers, but I want to learn more.
I have aquired a 887VAW. I have successfully configured it to connect to my DSL line etc and works a treat.
What I am struggling to do is have the WLAN traffic join the wired traffic. But I just cant get anywhere.
I dont yet have a config for the wlan side of things.
Please could someone point me in the right direction, and perhaps explain how the wlan and wired work together.
Many thanks,
Rich.
4 REPLIES 4
Highlighted
Beginner
Richard,
Your router has many different types of interfaces (WAN interface(s), switch ports, wireless radio's, etc.)  You can create a BVI (Bridge Group Virtual Interface) to interconnect your integraded wireless radio and switch ports.  Below is sample code from another post I made, which whould be a good example for you to work with.  If you are still having issues, please post your config so we can assist you further.
! Create an SSID and broadcast:
dot11 ssid MY_SSID
vlan 1
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii MY_PASSWORD
! Configure the physical interface, assuming you have a Dot11Radio0 interface
interface Dot11Radio0
no shutdown
no ip address
encryption vlan 1 mode ciphers tkip
ssid MY_SSID
! Configure a subinterface
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
! Configure a BVI, where x.x.x.x x.x.x.x is your LAN gateway IP address and subnet mask
interface BVI1
ip address x.x.x.x x.x.x.x
ip nat inside
ip virtual-reassembly
! Modify your VLAN configuration
interface Vlan1
no ip address
ip nat inside
bridge-group 1
! Other commands
bridge 1 route ip
Highlighted
I dont seem to have the same wlan interface as you list there.....
Here is my config (sanitised) that will help identify how its working with my router.
I am not overly keen on CLI and I have got to where I am so far with CCP.
Thanks for your help.
Building configuration...
Current configuration : 4405 bytes
! Last configuration change at 16:41:04 UTC Thu May 30 2013 by admin
version 15.2
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-167107849
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-167107849
revocation-check none
rsakeypair TP-self-signed-167107849
crypto pki certificate chain TP-self-signed-167107849
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31363731 30373834 39301E17 0D313330 35323931 36333732
  345A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3136 37313037
  38343930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  D8958879 96334023 C7721348 1070DC4D F442926E DAE3EEA6 BD3FD99D 8BDD34BD
  D9166C58 0AFD5374 58854B14 39C946E3 0775A4D5 F336EE41 559AFE00 8508F5B3
  5398CC8A BA4795E4 BDD3EA71 DCF22348 DE4F6828 DBD88D55 0F53037B 470CBBE4
  A9CF6F65 BAB60AC7 A8E02AFB 7A38D3C3 F92FA6AB AAA25363 0DECA681 2B413FF7
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 16801405 E9EE264C 7C8E111D C6EB5E0A F1E8532E 705A1430 1D060355
  1D0E0416 041405E9 EE264C7C 8E111DC6 EB5E0AF1 E8532E70 5A14300D 06092A86
  4886F70D 01010505 00038181 0071FD97 96103D51 213D90F9 9372AC15 13868C6C
  F78366C9 002017A3 4B87CAFF 2C5CF4BA 04E21D3F DBE36F98 897E8A83 CA7D5E1B
  B4F7CC8F 07DEF31B F05A34C9 DA12F3DF 1157C4C5 D9F20E32 7EFE6C78 DBBBD750
  8B1CC4D9 875E8F14 ED779D5C A843BCA7 0EB9C19A 20D07B82 7A7C0CF2 53962CE5
  344F955F 3294E963 7481775C 51
      quit
ip cef
ip domain name yourdomain.com
ip name-server 89.145.254.78
ip name-server 94.30.127.100
no ipv6 cef
license udi pid C887VA-W-E-K9 sn FCZ171793S5
controller VDSL 0
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description Daisy
pvc 0/38
  pppoe-client dial-pool-number 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username
ppp ipcp dns request
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 199 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 23 permit 10.0.0.0 0.0.0.255
access-list 23 permit any
access-list 199 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
line con 0
login local
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Highlighted
interface wlan-ap0
ip unnumbered Vlan1
The configuration needed by your router will be different than my example above.  You need to log into the module to configure wireless settings.  Please refer to these documents:
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/wlan.html
http://www.cisco.com/en/US/docs/routers/access/800/880/software/configuration/guide/880_basic_device_wireless_config.html
Highlighted
Beginner
It appears I had a duff router, so opened a TAC and already have the replacement in place.
Content for Community-Ad
