9200L Switch Priority
ssk8899
I have two 9200L switches stacked together. I am trying to config it to have switch 1 as priority 15 but i'm getting error and both switches are remaining at proirity1. I need some help here. Thank you.
Here are some details:
switch 1 priority 15
% Invalid input detected at '^' marker.
Model is C9200L-24T-4G
IOS XE Fuji-16.9.5
8 Replies 8
Leo Laohoo
Are you in enable mode?
balaji.bandi
the command should be executed in switch# prompt   (not in config t mode or switch>)
BB
ssk8899
Yes, i m in the enable mode
can you post show version and show switch
BB
ssk8899
Show version and Show Switch.
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    C9200L-24T-4G      16.9.5            CAT9K_LITE_IOSXE      BUNDLE
     2 28    C9200L-24T-4G      16.9.5            CAT9K_LITE_IOSXE      BUNDLE
SW3#
sh switch
Switch/Stack Mac Address : 3c13.cca3.9f80 - Local Mac Address
Mac persistency wait time: Indefinite
                                             H/W   Current
Switch#   Role    Mac Address     Priority Version  State
*1       Active   3c13.cca3.9f80     1      V01     Ready
2       Standby  3c13.ccbf.5100     1      V01     Ready
3       Member   0000.0000.0000     0              Provisioned
4       Member   0000.0000.0000     0              Provisioned
You can only set the priorities of Switch 1 and Switch 2.
Priorities of switch members that have not yet joined the stack cannot be set.
as suggested make sure you can only have different switch numbers and only you want to master and standby need to higher priority like 15 and 14.
follow below guide (cat 9300 still works for Cat 9200 too)
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
BB
Hello
How are you connecting to the stack via console port or remotely, if your via console make sure you are attached to the existing master switch console port?
Kind Regards
Paul
