We are gong to deploy a lot of 9300 switches, I have the first 3. These will not have internet access when they are deployed.
We are NOT using DNA-Advantage - we are happy using Network Advantage.
Can I simply connect the switches to the internet at HQ - activate smart licensing and activate the switch
Then cofigure and deploy the switch to site - please note - it will never have internet access at site.
What happens when the License expires ? Does the switch need to do periodic checks for valid license ?
Any help appreciated !
James
This is somewhat new to me too. But if this helps, once the licensing is activated on the switch, it will need to periodically check for a valid license. By default it will check every 30 days, but can go up to 60 or 90 days before being considered no longer active.
I'm in the process of deploying an "On Prem", formerly known as a Satellite server. Which is nothing more than a local machine that the switches can register their license usage and then the server synchronizes this utilization with Cisco Software Central. This may be a good solution for you.
As far as I know, once a switch is out of compliance, the services shouldn't degrade, but there may be some gotchas I'm not yet aware of. It may however, make getting support or other needs accomplished.
Anyway, just my understanding at this point.
Hopefully this helps a bit.
