KonstantinC
Beginner
A couple of questions about RSPAN
Hi!
Suppose we want to redirect traffic from server on Gi0/1 port on switch SW1 to some destination on SW2 through remote-span vlan 10
http://s42.radikal.ru/i098/1211/47/8a8476ad4888.png
Switch SW1 configuration:
monitor session 1 type rspan-source
source interface Gi0/1
destination remote vlan 10
Suppose that server generates 500MBit\s of traffic.
Question is at what moment the traffic physically will go through trunk to SW2?
There are two trunk ports on SW1 where vlan 10 is allowed.
How SW1 knows where to direct traffic?
1 ACCEPTED SOLUTION
bissaha
HI,
Plesae check the RSPAN config guideliens
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_13_ea1/configuration/guide/swspan.html
Note
As RSPAN VLANs have special properties, you should reserve a few VLANs across your network for use as RSPAN VLANs; do not assign access ports to these VLANs.
--To avoid unwanted traffic in RSPAN VLANs, make sure that the VLAN remote-span feature is supported in all the participating switches.
So to ans your queries see inline
--Question is at what moment the traffic physically will go through trunk to SW2?
Ans:----As soon as we define RSPAN vlan & considering its allowed in the trunk with below configs defined, we should get the traffic onto SW2
SW1
conf t
vlan 10
remote-span
monitor session 1 source interface gi0/1
monitor session 1 destination remote vlan 10
SW2
conf t
monitor session 1 source remote vlan 10
monitor session 1 destination interface X/Y
Q:--How SW1 knows where to direct traffic?
Ans:--If you allow that vlan over to both the SW3 and SW2, it will forward the traffic to both however if you dont have configs for RSPAN (monitor session 1 source remote vlan 10) on the respective switches traffic will be dropped.
Hope this helps.
Biswa.
2 REPLIES 2
bissaha
HI,
Note
SW1
conf t
vlan 10
remote-span
SW2
conf t
Hope this helps.
Biswa.
Thanks, bissaha
So RSPAN is a dangerous technology
In my case I have 6500 with many trunks, there is also server connected that generates 3Gbit\s of traffic.
If I'll configure
monitor session 1 destination remote vlan xx
many trunk links where vlan xx is not excluded will be overloaded...
