I want to prevent two Layer 3 Switches from becoming DR/BDR's. I know that I can use the IP Ospf Priority 0 command. But can I use that command within the OSPF process instead of applying it to an interface ?
DR is a property of an interface and not the entire router so I am afraid this command cannot be configured under ospf process but should be configured on per interfaces.
Ankur
Learn, share, save
