aaa authentication dot1x default group radius none
mohammed hashim
I do have Radius implemented for 802.1x,
I am using the following switch:
I want the switch to allow user access if Radius server is down. The issue with the following command, I dont get "none" option:
According to Cisco documentation that this command is valid:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/a1/sec-a1-cr-book/sec-cr-a1.html
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/security/a1/sec-a1-xe-3se-3850-cr-book/sec-a1-xe-3se-3850-cr-book_chapter_00.html
Can you please help me on what to do on this ?
Thanks for the feedback. With multiauth mode you can also try the below interface command:
"authentication event server dead action reinitialize vlan 1"
(instead of "... authorize vlan 1").
There are known bugs related to the critical Vlan for various platforms and various IOS releases. If unsuccessful you MAY consider to update your IOS.
Best regards,
Antonin
6 Replies 6
mohammed hashim
any help please ?
I am not sure what is your VLAN and Switch configuration but try like this:
aaa new-model
aaa authorization network default group radius
dot1x system-auth-control
interface GigabitEthernet1/0/2
 switchport mode access
 authentication event fail action authorize vlan 2 --> If authentication failed then Assign VLAN 2
 authentication event no-response action authorize vlan 3 ---> If no responce then it will assign VLAN 3
 authentication event server dead action authorize vlan 3 ----> If all confgured server dead marked
authentication host-mode multi-host authentication port-control auto dot1x pae authenticator
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Yes, the option "none" is not available with your IOS release. You can achieve what you aim via the "authentication event server dead action authorize" interface configuration command.
Best regards,
Antonin
Hi dears,
sorry for the late update on this,
I tried the suggested commands, but unfortunately the issue still persists, the switch does not allow the endpoint to access the network if Radius is down. I tried several variations of the following commands:
interface GigabitEthernet0/17
authentication event fail action authorize vlan 1
authentication event server dead action authorize vlan 1
authentication event no-response action authorize vlan 1
authentication event server alive action reinitialize
authentication host-mode multi-auth
authentication order dot1x
authentication priority dot1x
authentication periodic
authentication violation restrict
mab
snmp trap mac-notification change added
snmp trap mac-notification change removed
snmp trap link-status permit duplicates
dot1x timeout quiet-period 30
spanning-tree portfast
end
anything can be done?
Best regards,
Antonin
Thank you, this solved my problem.
