about CSMA/CD
yuanguitao
Hi, everyone. Now i was confused by the CSMA/CD. as we all know this protocol work in the layer 2. and this protocol promise only one connection can trasmit or receive data online at one moment. if so QQ截图20130910170600.png,Can PC-A communicate with other clinets int the fig above.what if i exchange the hub for a switch?
The other question is that my network adapter has deployed to 100 full deplux now witch connects a switch directly, and i don't know if CSMA/CD is working now ? because CSMA/CD only allow half-deplux.  I am waiting for your answers. thank you !
azmunnabi
Hi WEI,
Here is some light on Half/Full Duplex and CSMA/CD.
Half Duplex and CSMA/CD:
1. Hub and Co axial cable operate in half duplex mode. (Communication is possible in one direction at an instant.)
2. CSMA/CD is an access method used in half duplex communication.
CSMA/CD: As in half duplex - only one direction communication is possible at a time. There exists chance of collision when two ends of the physical medium tries to use the medium at the same time.
In case of collision JAM is invoked, send to all stations, back off timer starts and frame is resend.
[Refer CSMS/CD operation]
3. Thus in half duplex (CSMA/CD is operating); bandwidth is shared.
The communication between two ends may be slow because of collision and retransmission, but it doesn't mean that the communication will not happen as retransmission is always there. ( although the number of retransmission may be limited). Yes because of shared bandwidth the communication is slow.
[So In your topology Host A can communicate to any other PC. Any two device can communicate]
Full Duplex:
1. Switch and Copper twisted pair operate in full duplex. ( Communication is possible in both direction at the same time.)
2. No use of CSMA/CD in Full Duplex. CSMA/CD is operative when device is operating in half duplex.
As communication is possible in both direction in full duplex mode, there is no chance of collision and no mechanism is required to detect the same.
HUB and Switch:
Hub: Hub always operate in half duplex mode. CSMA/CD is operative.
- Hub brings in all the connected devices to creates one segment and all the devices are then in one collision domain.
Switch: Switch operates in full duplex mode by default. No CSMA/CD operates.
- Switch separates the network segment. Each port of switch creates the segment and is one collision domain.
When Hubs is connected to Switch; the link is supposed to work as half duplex. (As hub operates in half duplex mode)
So the switch port connected to hub is configured to operate in half duplex mode only.
Thus CSMA/CD will now operate and it is collision prone segment.
* microsegmentation: Referred by Cadet and Joseph seems to me is significant in Switches.
          But can't say much on this term. If someone can add on this, it will be of help.
Hope all the above points help.
Please correct if I am wrong at some or if some need modifications.
10 Replies 10
cadet alain
a switch lets you do full-duplex by microsegmentation as each port is now its own collision domain and in full duplex CSMA-CD is disabled as it has no more use now.
Alain
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Sure, and if you exchange the hub with a switch PC-A can still communicate with the other clients.  Whether a hub or switch, your 3 clients are all in the same L2 domain.  One advantage of a switch, unicast traffic between any two hosts is usually not seen by any other hosts, preserving bandwidth.  If you had 4 hosts, hosts A and B could communicate "privately" while hosts C and D did too.  With a hub, all 4 hosts would share the same bandwidth.  (NB: this is the [switch] microsegmentation that Alain refers to.)
When full duplex is activated, CSMA/CD is not longer working as it's no longer needed.  Full duplex requires the connection to be physically p2p between a pair of devices.  CSMA/CD is designed to share the same "wire" with multiple hosts.
Hubs cannot do full duplex, switches may optionally support it.
azmunnabi
Hi WEI,
Full Duplex:
HUB and Switch:
Disclaimer
Posting
For backward compatibility, switch ports normally default to half duplex.  If they and the connected device support auto-negotiation, they will generally negotiate full-duplex.  Otherwise, you normally have to "hard code" the port for full duplex operation.
Before there were switches, one way to improve LAN performance was to segment the existing LAN so not as many hosts were in the same broadcast domain; sharing the same bandwidth.  This might be accomplished by using a bridge (a modern switch is also known as a multi-port bridge).
Microsegmentation is placing a single host on its own LAN segment.
thanks for your terrific answer. well, if pc or other clients connect to a switch, they will be set to full duplex auto, because the switch can provide a single interface for each client just like providing a individual path. so it won't come up with collison between them, then CSMA/CD will be out of use. am i right?
but what if two switches(access layer) connected and deployed trunk? How to avoid collison? will csma/cd work?
The last question, if the cable between a switch and a client(may be pc, AP, and so on) cannot work normallly. for example, the distribution frames is not so stable, the client would be up or down randomly. if that can cause collsion?
Disclaimer
Posting
Yes.
Two switches can do either half duplex for full duplex, the latter avoids collisions although the latter might overflow a queue dropping frames/packets.  Normally, if supported, full duplex is preferred because it both avoid collisions and allows two way concurrent transmission (effectively doubling the available bandwidth).
No, because when operating in CSMA/CD mode, rules are to listen first before attempting to transmit.  This would apply whether host has been on-line for some time or just activated the link.  A collision is when, after listening, wire appears available, multiple hosts begin transmitting at about the same time.  The hosts should detect the collision, stop transmitting, and then each host waits a "random" amount of time before trying again.  (The independent random wait is to try to avoid a cycle of hosts waiting the same amount of time, again seeing the wire isn't being used, and again transmitting at about the same time.)
Karan Puri
Make u short ans..
When u set half duplex in an interface; device keep on monitoring tx line...
Now which algorithm monitor this, ans is csma/cd..
u can do some lab test the csma/cd... set one side full duplex and other end half.. n check sh int f0/0 ! in coll!err!tx.. u will find collision...
Thanks Joseph and Karan for correcting.
It was wrongly written.
Thanks to clarify that Switch defaults to Half duplex for backward compatiblity.
@Joseph:
As you have written:
Can you please put some example where hard coding needs to be done and auto negotiate fails.
How can we know in auto scenario that auto negotiation is failed, and the port needs to be hard coded?
What I make of Switch and connecting device is:
A Switch operates by itself weather the connecting device is hub, switch, host or router.
Full Duplex ethernet (free of CSMA/CD) is used when, connection is between Switch, Host or Routers.
Whenever, Hub is invloved, half duplex (CSMA/CD operative) is used.
Auto-Detect Mechanism:
It first decide the exchange capabilities and then see if the device can run full duplex and if it can't it will run half duplex.
Disclaimer
Posting
@Joseph:
How you know it fails, if both sides of the link say they support auto, but they don't establish full duplex, it failed.  Then you can often manually set full duplex, which should be done on both sides.  (Note - early on, you would often see failure between different vendor NICs, but it's unusual for it to fail now a days on modern equipment.)
There's also the situation where one or both NICs support full duplex but they don't support auto.  Then you have to hard code it.  (Don't see much of this anymore either.)
yuanguitao
Great, thank you very much.
