AC Power Supply with PoE for Ethernet modules in ISR G2
yiqinc2004
While configuring PoE Ethernet EHWIC PoE modules with ISR G2 routers Cisco DCT gives a warning to select AC Power Supply with PoE ‘PWR-3900-POE’. Do we need to select the PoE power supply for Enhanced EtherSwitch SM PoE modules also (at present it does nt show any warnings)?
Raju Sekharan
POE feature doesn't work without POE power-supply
Q. Do the default power supplies provide any PoE capability?
A. There is no connection to the PoE bus in the routers without the PoE power-supply option.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/qa_c67-612908.html
Raju
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
