Access point not working
sathyasav
I have a 1130 cisco access point,we are using this for wireless cisco IP phone connectivity to the network.Earlier access point was woring fine and we were able to make calls through IP phone.But we have relocated to new place.Now the access point is not working and we are not able to make the calls on the wireless IP phone as the access point is not working.But the access is in the netwrok and we are able to ping the IP address of the Access point.
We are contonuously getting the below loggs on Access point and the access point is getting power from the ethernet port of the switch not through the external powerr adaptor.
error message:
: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C
4507R (0012.7fb6.6e6c).
Please tell me is this error message the source of the issue or how to make this work.
Sathya.
6 Replies 6
glen.grant
   Either the power injector or the switchport is not supplying enough power for the AP for some reason and the AP is shutting the radios off .  Troubleshoot the power issue.
ebarticel
Level 4
Level 4
Also check the power settings on the switch port that is connected to AP and that cdp is enabled on that switch port.
Leo Laohoo
1.  Some 4000/4500 line cards will only operate up to 7.5w of PoE.  Can you post the output to the command "sh module"?
2.  You sure you have enough PoE power?
Hi leo,
i amsure that switch has enough POE power but the issue is that the switch is not providind the power more than 7.3 as you have mentioned.
ASB-BAN-SW58>sh mod
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1     2  1000BaseX (GBIC) Supervisor(active)    WS-X4515           JAE09159BSF
2     2  1000BaseX (GBIC) Supervisor(standby)   WS-X4515           JAE0820HBC5
3    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE084500TS
4    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0845ZRPV
5    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0842YAEK
6    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0842YFKM
7    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0842YFQG
M MAC addresses                    Hw  Fw           Sw               Status
1 0012.d97c.c800 to 0012.d97c.c801 4.0 12.2(20r)EW1 12.2(18)EW3      Ok
2 0012.d97c.c802 to 0012.d97c.c803 3.1 12.1(20r)EW1 12.2(25)EWA8,    Ok
3 0012.7fb6.6e40 to 0012.7fb6.6e6f 2.7                               Ok
4 0012.7fb5.f850 to 0012.7fb5.f87f 2.7                               Ok
5 0012.4373.bc40 to 0012.4373.bc6f 2.7                               Ok
6 0012.439a.aff0 to 0012.439a.b01f 2.7                               Ok
7 0012.439a.6040 to 0012.439a.606f 2.7                               Ok
ASB-BAN-SW58>sh power inline module 3
Available:1400(w)  Used:895(w)  Remaining:505(w)
Interface Admin  Oper            Power(Watts)     Device              Class
                            From PS    To Device
Fa3/1     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/2     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/3     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/4     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/5     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/6     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/7     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/8     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/9     auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/10    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/11    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/12    auto   off        0.0        0.0        n/a                 n/a
Fa3/13    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/14    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/15    auto   off        0.0        0.0        n/a                 n/a
Fa3/16    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/17    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/18    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/19    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/20    auto   on         6.3        6.3        Cisco IP Phone 7960 n/a
Fa3/21    auto   on         6.3        6.3        Cisco IP Phone 7960 n/a
Fa3/22    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/23    auto   off        0.0        0.0        n/a                 n/a
Fa3/24    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/25    auto   off        0.0        0.0        n/a                 n/a
Fa3/26    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/27    auto   off        0.0        0.0        n/a                 n/a
Fa3/28    auto   off        0.0        0.0        n/a                 n/a
Fa3/29    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/30    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/31    auto   off        0.0        0.0        n/a                 n/a
Fa3/32    auto   off        0.0        0.0        n/a                 n/a
Fa3/33    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/34    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/35    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/36    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/37    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/38    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/39    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/40    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/41    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/42    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/43    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/44    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/45    auto   on         7.0        7.0        Cisco PD            n/a
Fa3/46    auto   on         6.3        6.3        Cisco IP Phone 7940 n/a
Fa3/47    auto   off        0.0        0.0        cisco WS-C4507R     n/a
Fa3/48    auto   off        0.0        0.0        n/a                 n/a
Totals:          38   on    240.1      240.1
ASB-BAN-SW58>
The access poing is connecetd to the port fa3/45 on the switch.
Please let me know how to resolve the issue.
First check the AP power needs and the max it support. Don't want to "fry" it.
You may need to configure a static value for that port.
interface fa3/45
power inline static 15400
no cdp enable    -->this is optional, usualy in default settings cdp discover the power needs of the device.
thats 15.4W which is max that a port can supply. By setting a static value it give that port priority in power allocation. The only disadvantage is that power will be supplied to this port even when a poe device is not connected.
Hope this helps
Eugen
You are using WS-X4148-RJ45V card.  According to the "Cisco Catalyst 4500 Power over Ethernet Capabilities" can support only up to 7.0 w.  The WAP requires a minimum of 15.0 w PoE.
