Access Switches
saquib.tandel
Hello
Transparent mode Vs Client mode which mode is recommended for access switches
Any template from cisco for access switch configuration covering needed security
thanks
ST
Steven Clinton
Here is a basic guide to secure your switch:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080120f48.shtml
Also there is an autosecure option, but that can sometimes "over-secure" your devices, to the point where you can have problems reaching places you want to reach.
Please mark as correct if this answers your question :-)
5 Replies 5
Bilal Nawaz
If you are utilising VTP in a server client environment then use client.
If you are to create vlans separately on the switch, use transparent. (Commonly used)
Please ensure that you do not use the server mode as this could possibly wipe vlans out for an entire estate.
Please see this for further details
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
vtp can be confusing at timee
access-switches requie client mode to receive the vtp database config off the vtp server
however this all depends on something a revison number
vtp servers and client read which has the highest value and the one with the highest value ( either vtp server or client) will propergate its vlan database to all other vtp server and clients.
transparent mode doesnt accept vtp configurarion but listens and forwards it.
so if you need to add a new switch to the network then change the switch to transparent mode then to client and the revision number will default to 0 and you will be safe to all the new switch to the network
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
Steven Clinton
Unless you have a large enterprise/campus setup that requires end-to-end vlans, it is a best practice to use transparent.
Even a client with a higher revision number can overwrite a server with a lower revision.
thanks all
can someone share steps to secure an access switch
Steven Clinton
