Accessing switch web management
kierangio123
Hi there I need help urgently I can access the homepage of my catalyst 2950 but I cant get into it because java is to new I need an older version 1.2,1.3 or 1.4 I have download CMS plugin dont know how to get it on it didnt help.
6 Replies 6
Dan Lukes
You should ask on community dedicated to technology your's question is related to, e.g. LAN, Switching and Routing. Your chances to receive valuable reply are rather low otherwise.
Please use blue [ EDIT ] button to move this thread to it.
Also note there are volunteers only. For urgent help call Cisco's support center.
I have called them they cant help.
It i possible as 2950 is no longer supported device.
Well, you may not welcome such advice, but consider to learn how to use CLI.
It doesn't depend on third party things like Java or a browser or Windows ...
This discussion has been reposted from Additional Communities to the LAN, Switching and Routing community.
2950 is already EOS/EOL state, that's like the grandpa of 2960's
Sadly, cisco cannot support you with that device anymore
Also, have you tried the config
and Dan Lukes is right, consider CLI, almost all of the deployments we have encountered always use CLI and http/https is disabled/note used.
Heck, the certification exams even use CLI. :D
LJ Gabrillo
Level 5
Level 5
1. Update your Java, make sure it matches your OS (32 or 64bit)
2. Use internet explorer
3. Try to enable both HTTP and HTTPS for isolation, sometimes using HTTPS causes issues
#ip http server
#ip http secure-server
#ip http authentication-local          -DO NOT FORGET THIS COMMAND
#username cisco privilege 15 password cisco
