03-09-2013 02:20 AM - edited 03-07-2019 12:08 PM
Dear Freinds of Cisco family
I will be replacing my primary ACE blade and am wondering if when I reconfigure the admin context and insert the blade in the chasis , with the ft groups and vlans . Is there any risk for the newly inserted primary blade push Blank config to my current active (secondary Mate) .
Pls guide me step by step how to acheive this so that i do not run into any problem of blank config as i did not found any doc on this .
Note i have preempt enabled in all my context and auto sync also enabled in all context
Pls guide me what all basic config i need to do whch will be sufficient for the unit to download full config from active secendary mate
03-10-2013 05:31 PM
Hi Shirshendu,
Make sure you make a backup copy of all your ACE configuration for the all
the context before doing any replacement. Also, make sure that the current
primary ACE module has all the updated configuration
- Here are some documentation on how to replace the ACE module in the
switch:
1. Preparing to install/remove module -
http://www.cisco.com/en/US/partner/docs/interfaces_modules/services_modules/
ace/installation/note/aceinote.html#wp51611
2. Remove the ACE module -
ace/installation/note/aceinote.html#wp42206
3. Install the new ACE module -
ace/installation/note/aceinote.html#wp42094
- Once the new ACE module is installed, setup the ACE according to the link
below and load the same software version as that of the primary ACE:
ace/v3.00_A1/configuration/administration/guide/basiccfg.html
ace/v3.00_A1/configuration/administration/guide/upgrade.html
- Configure the redundancy on the new ACE and synchronize the configuration:
ace/v3.00_A1/configuration/administration/guide/redundcy.html
Inayath
*Plz rate the usefull posts.
03-11-2013 08:07 AM
Inayath
Not able to open the links any links you provided
Forbidden File or Application
03-11-2013 09:33 AM
Hi Shirshendu,
Please copy the entire link and paste on the browser.
Eg;
Starts from www.cisco.com till ent of .html#wp51611
Inayath
