acl and vacl
suthomas1
Level 6
Level 6
What is the precise difference between normal acl that is applied to an interface or svi vlan interface and vlanacl(VACL)?
does VACL mean that traffic within a single vlan can be controlled?
thanks in advance.
Hi thomas,
Vlan acl is the common way to do this,see the sample onfiguration
vlan access-map TEST 10
action drop
match ip address 100
vlan access-map TEST 20
action forward
vlan filter TEST vlan-list 10
access-list 100 permit ip host 10.10.1.1 host 10.10.1.2
pls rate if helpfull
shehin.pm
cadet alain
ACL applied to physicla L2 port is a port based ACL which can only be applied inbound and can be a MAC or IP ACL, the MAC ACL working for non-IP traffic.
ACL applied to routed port or SVI is a routed ACL which is the same as a traditional ACL on a router.
A VACL is an ACL to control traffic inside a VLAN.
Regards.
Alain.
Thank You Alain. That means, if we have a vlan10 with 2 systems 10.10.1.1 and 10.10.1.2. If these two neednt talk to each other, i can create a acl and apply to one of the physical ports?
thanks.
Hi thomas,
action drop
action forward
shehin.pm
