11-23-2022 11:59 PM
I was applying an access list on a switch SVI on nexus 9300 series switch but when I apply the access list on the out direction of the SVI it blocks traffics to the servers on the VLAN and that's want I want and perfect but the problem is it blocks traffics originating from the VLAN. Please help on this.
Solved! Go to Solution.
11-24-2022 03:46 AM
Hello Advisor,
Additional information, the ACL drops an independent traffic which is orginating from the server itself not an established traffic from outside to servers.
11-24-2022 12:07 AM
ACL basic rules of access-list :
IN = Traffic originating from within the vlan interface
OUT = Traffic coming from outside vlan interface
still have an issue post the config.
11-24-2022 12:22 AM
Here is the config
IP access list Access-to-VLAN118
40 permit tcp addrgroup FROM_OUT_TO_MAIL addrgroup Mail-Servers portgroup Mail-ports
41 permit tcp addrgroup ALL_BOA_NET addrgroup Mail-Servers portgroup Mail-ports
42 permit ip addrgroup CDE_VLANS any
43 deny ip any addrgroup Mail-Servers
44 permit ip any any
interface Vlan118
description INFRASTRACTURE SERVICE
no shutdown
mtu 9216
vrf member DATACENTER
ip access-group Access-to-VLAN118 out
no ip redirects
ip address 192.1.18.2/24
no ipv6 redirects
vrrpv3 10 address-family ipv4
address 10.1.18.1 primary
object-group ip address Mail-Servers
10 host 192.1.18.16
20 host 192.1.18.23
30 host 192.1.18.26
40 host 192.1.18.27
11-24-2022 12:39 AM
OUT must work but where is portgroup <object-group> you use ???
11-24-2022 12:48 AM
I didn't get the question.
we use this access list to restrict access to the mail servers to this allowed ports only
object-group ip port Mail-ports
eq 143
eq 443
eq 993
eq 25
11-24-2022 12:57 AM
deny traffic originate from Server.
Server-SVI-Client(outside)
the Client initiate the traffic the traffic will pass through ACL OUT no issue
the Server initiate the traffic the traffic will pass through SVI because there is no ACL IN apply to SVI
BUT
the return traffic to Server (the traffic that server initiate it) must allow by ACL OUT
so which traffic you notice it drop by ACL OUT ??
11-24-2022 02:27 AM
Can you define is what is dropping ? (what is the source IP)
43 deny ip any addrgroup Mail-Servers - other than permit rest all denied as per this rule ?
11-24-2022 12:57 AM
Kindly provide all groups and ACL (for this question) also tell us who is the server and who is another device. And where to where is it blocking?
11-24-2022 03:06 AM
Here is the scenario
11-24-2022 03:11 AM
object-group ip address ALL_BOA_NET
host 192.0.0.0/8
object-group ip address FROM_OUT_TO_MAIL
host 10.1.1.21
host 10.1.1.23
host 10.1.12.38
host 10.1.12.39
host 10.1.12.51
host 10.1.39.197
host 10.1.39.51
host 10.1.39.70
host 10.100.2.101
host 10.100.2.199
host 10.100.2.98
host 10.100.2.99
host 10.101.13.200
host 10.101.14.142
host 10.101.14.150
host 10.101.14.151
host 10.101.14.20
host 10.101.14.70
host 10.101.2.100
host 10.101.2.175
host 10.101.2.176
host 10.101.2.178
host 10.101.2.180
host 10.101.2.200
host 10.101.2.211
host 10.101.2.30
host 10.101.2.45
host 10.101.2.51
host 10.101.2.61
host 10.101.2.70
host 10.2.2.35
host 10.3.26.30
host 10.3.28.46
host 10.3.39.51
host 10.4.2.67
host 172.20.18.44
host 172.20.18.26
host 172.20.18.62
host 172.20.18.95
host 172.20.22.30
host 172.20.22.31
host 172.21.13.95
host 172.21.13.96
host 192.168.150.12
11-24-2022 03:23 AM
I am Now finish my last point about the FW with ACL, so I think I have solution here
Server-SVI ACL(OUT)-Client (outside)
traffic initiate from the client pass through ACL OUT no problem
traffic initiate from the Server need to return back through ACL OUT and it drop, so we need to add line the make only return back traffic to Server without open ACL, this can be done by add established keyword.
Note:- this solution only for TCP traffic.
11-24-2022 03:41 AM
Hello Advisor,
Thank you indeed for the information but where should I apply the keyword I mean on the existing (out) access list or I should write another access list for the (in)?
11-24-2022 03:43 AM
permit tcp any any establish <<- add this line to ACL OUT, and check
again this solution only for TCP traffic.
11-24-2022 03:46 AM
Hello Advisor,
11-24-2022 04:02 AM
the number we add line is important which come after the traffic initiate from client.
NOTE:- when we deal with ACL we do test for all case
permit tcp any any establish <<-- it need to add here.
