ACL question
burleyman
Level 8
Level 8
ACL's are my weak spot, I don't do many so it has not sunk in like it should.
My question is, when I do a "show access-lists" and I see (23 Matches) does that mean since the reboot there have been 23 packets that matched that ACL? And if I do not see any matches that it means no packets matched the ACL?
Thanks for your help,
Mike
2 Accepted Solutions
Jerry Ye
Yes for both questions.
jerry
cadet alain
matches are packets matching ACE since last clearing of counters and if there is no match then packets are not hitting your ACE.
Regards.
Alain.
Jerry Ye
jerry
cadet alain
Regards.
Alain.
Thank you both for your help in confirming what I thought.
Mike
