ACL statement not working properly
Kevin Melton
Level 2
Level 2
I am working at a customer site today and have an issue with an FTP transfer. The user initiates an FTP transfer from his server to a public FTP site. He is able to login OK but then cannot list or transfer files.
We have an Access-list on the VLAN that he is a member of. We know that the Access-list is denying the connection attempt as we can see it in the log. It matches the list statement which is 730 "deny ip any any log (748433 matches)" and then we see this is the log "Aug 31 12:04:16.765: %SEC-6-IPACCESSLOGP: list LoSCADA-vlan104 denied tcp 66.112.157.210(20) -> 192.168.104.59(4534), 1 packets"
Here is the statement we have to permit this in the ACL itself:
"221 permit tcp host 66.112.157.210 host 192.168.104.59 eq ftp-data"
Here is the configured statement on the VLAN interface:
"ip access-group LoSCADA-vlan104 out".
I need help to figure out why my ACL statement is not correctly written. When I remove the ACL from the interface, the FTP transfer works.
Joseph W. Doherty
"denied tcp 66.112.157.210(20) -> 192.168.104.59(4534), "
Perhaps try:
221 permit tcp host 66.112.157.210 eq ftp-data host 192.168.104.59
7 Replies 7
Edison Ortiz
In your ACL, you have 192.168.104.59 with the server port but your current task is not of a server but of a client.
Your FTP server is initiating the transfer so its function is of a FTP client. FTP client will use a random high port (1024 and above).
HTH,
__
Edison.
Joseph W. Doherty
Perhaps try:
Laurent Aubert
Could you post the config of the ACL ?
Laurent.
Laurent Aubert
Laurent.
Yes and thanks for the help.
The ACL is attached.
I asked for the ACL just in case but the correct explanation has already been provided by Edison and Joseph.
Laurent.
hello
can u try
permit tcp any any established
also what about ftp control port (21)
