ACL
joe.marcelo9
How can I add a line without removing the deny statement and applying again.
access-list 50 permit 192.168.1.0 0.0.0.255
access-list 50 permit 192.168.2.0 0.0.0.255
access-list 50 permit 192.168.3.0 0.0.0.255
access-list 50 permit 192.168.4.0 0.0.0.255
access-list 50 permit 192.168.5.0 0.0.0.255
access-list 50 deny any any
Lucien Avramov
Level 10
Level 10
You can not.
You need to remove and re-add the ACL.
simontibbitts
Hi Joe.
If your IOS supports it then you can do it like this:
R1#show access-list 50
Standard IP access list 50
10 permit 192.168.1.0, wildcard bits 0.0.0.255
20 permit 192.168.2.0, wildcard bits 0.0.0.255
30 permit 192.168.3.0, wildcard bits 0.0.0.255
40 permit 192.168.4.0, wildcard bits 0.0.0.255
50 permit 192.168.5.0, wildcard bits 0.0.0.255
60 deny any
R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#ip access-list standard 50
R1(config-std-nacl)#51 permit 192.168.6.0 0.0.0.255
R1(config-std-nacl)#exit
R1(config)#exit
51 permit 192.168.6.0, wildcard bits 0.0.0.255
60 deny any
R1#
Simon
