Active HSRP does not recognize standby, but standby HSRP recognizes HSRP active.
dcamarotto
I have two switches configured as follows:
(C3750X), Version 15.0(2)SE8
interface Vlan202
 description Rede_X
 ip address 186.230.4.62 255.255.255.240
 standby version 2
 standby 1 ip 186.230.4.59
 standby 1 priority 240
 standby 1 preempt
 glbp 202 ip 186.230.4.60
 glbp 202 priority 240
 glbp 202 preempt
(C3750E), Version 12.2(55)SE10
interface Vlan202
 description Rede_X
 ip address 186.230.4.61 255.255.255.240
 standby version 2
 standby 1 priority 250
 standby 1 preempt
 standby 1 track 10 decrement 11
 glbp 202 priority 250
 glbp 202 preempt
 glbp 202 load-balancing weighted
 glbp 202 weighting track 10 decrement 11
end
When I check the HSRP is working correctly, see the following situation:
(C3750x), Version 15.0(2)SE8
SW01#sh standby brief
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Vl202       1    240 P Standby 186.230.4.61    local           186.230.4.59
SW01#sh glbp
ISW01#sh glbp bri
SW01#sh glbp brief
Interface   Grp  Fwd Pri State    Address         Active router   Standby router
Vl202       202  -   240 Standby  186.230.4.60    186.230.4.61    local
Vl202       202  1   -   Active   0007.b400.ca01  local           -
Vl202       202  2   -   Listen   0007.b400.ca02  186.230.4.61    -
Vl202       202  3   -   Listen   0007.b400.ca03  186.230.4.61    -
SW01#
SW02#sh standby brief
Vl202       1    250 P Active  local           unknown         186.230.4.59
SW02#sh glbp brief
Vl202       202  -   250 Active   186.230.4.60    local           186.230.4.62
Vl202       202  1   -   Listen   0007.b400.ca01  186.230.4.62    -
Vl202       202  2   -   Active   0007.b400.ca02  local           -
Vl202       202  3   -   Active   0007.b400.ca03  local           -
                  GLBP running fine but HSRP not.  The only information I can get about is this:
SW02#
Jun 30 13:04:52.558: %GLBP-6-FWDSTATECHANGE: Vlan202 Grp 202 Fwd 2 state Listen -> Active
Jun 30 13:04:52.558: HSRP: Vl202 Nbr 186.230.4.62 Adv in, active 0 passive 0
Jun 30 13:04:52.558: HSRP: Vl202 Nbr 186.230.4.62 is no longer passive
Jun 30 13:04:52.558: HSRP: Vl202 Nbr 186.230.4.62 destroyed
Jun 30 13:22:03.969: HSRP: Vl202 Nbr 186.230.4.62 Adv in, active 0 passive 1
Jun 30 13:22:03.969: HSRP: Vl202 Nbr 186.230.4.62 created
Jun 30 13:22:03.969: HSRP: Vl202 Nbr 186.230.4.62 is passive
Jun 30 13:22:04.967: %GLBP-6-FWDSTATECHANGE: Vlan202 Grp 202 Fwd 1 state Active -> Listen
Jun 30 13:22:14.974: %GLBP-6-FWDSTATECHANGE: Vlan202 Grp 202 Fwd 1 state Listen -> Active
Jun 30 13:22:17.969: %GLBP-6-FWDSTATECHANGE: Vlan202 Grp 202 Fwd 3 state Listen -> Active
Jun 30 13:22:47.018: %GLBP-6-FWDSTATECHANGE: Vlan202 Grp 202 Fwd 1 state Active -> Listen
 What is wrong? I've done upgrade the IOS version and the result has been the same.
Robert Falconer
Have you tried HSRP v1 instead? Do you have some requirement to use v2?
You could try testing the 3750x at version 12 to match the 3750e.
Are there any other standby groups on either switch that share the group number of 1?
Hi Robert,
                yes. I tried v1 and grp 0 to HSRP. I put this configuration because it is a final configuration to my Customer.
The software version I got the upgrade based on the version I'm right on the Cisco website. So I tried to look Bug tool kit if there is any bug related but could not find anything.
