Add Module Card C2811
hilldamanik
Dear friends in the community,
Please help. I've just added a card 2FE in the Cisco 2811.
but when I
"sh run" sh interface and sho ip interface brief. card is no
I received an error message as follows on log:
*Oct 23 05:12:12.515: %GT96K_FEWAN-1-UNKNOWN_WIC: NM slot 0, wic card has an unknown id 53B
*Oct 23 05:12:12.515: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 216)) is not supported on this image.
           Please issue "show diag" in fully loaded IOS image
           to get the PA's information and verify if it is supported
           by this image, a newer version may be needed.
The following version IOS Version:
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:09 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
JKTTLC_AJN-DKI_DRC uptime is 35 minutes
System image file is "flash:c2800nm-ipbase-mz.124-3i.bin"
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FTX1205A5PN
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
which version of the 2FE2W do you have ? Can you post the output of 'show diag' ?
Dear gpauwen,
this result show diag:
not detection
TTLCDRC#show diag
Slot 0:
        C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC120342X9
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-26920-04
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 04
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Processor type           : 87
        Hardware date code       : 20080120
        Chassis Serial Number    : FTX1205A5PN
        Chassis MAC Address      : 001e.7a60.2500
        MAC Address block size   : 24
        CLEI Code                : COM7R00ARA
        Product (FRU) Number     : CISCO2811
        Part Number              : 73-10258-05
        Version Identifier       : V05
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 32 30 33 34 32 58 39 40
          0x10: 03 E7 41 01 00 C0 46 03 20 00 69 28 04 42 41 30
          0x20: 88 00 00 00 00 02 04 03 00 81 00 00 00 00 04 00
          0x30: 09 87 83 01 32 65 F8 C2 8B 46 54 58 31 32 30 35
          0x40: 41 35 50 4E C3 06 00 1E 7A 60 25 00 43 00 18 C6
          0x50: 8A 43 4F 4D 37 52 30 30 41 52 41 CB 8F 43 49 53
          0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12
          0x70: 05 89 56 30 35 20 D9 02 40 C1 FF FF FF FF FF FF
        WIC Slot 2:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-33018-01
        Part Number              : 73-12949-01
        Board Revision           : A0
        Fab Version              : 03
        PCB Serial Number        : FOC19110NTX
        RMA History              : 00
        Product (FRU) Number     : HWIC-2FE
        Version Identifier       : V02
        CLEI Code                : COUIAFUCAB
        Base MAC Address         : a89d.2150.4a7e
        Connector Type           : 01
          0x00: 04 FF 40 05 3B 41 02 00 C0 46 03 20 00 80 FA 01
          0x10: 82 49 32 95 01 42 41 30 88 00 00 00 00 02 03 C1
          0x20: 8B 46 4F 43 31 39 31 31 30 4E 54 58 03 00 81 00
          0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 32 46 45 20
          0x40: 20 20 20 20 20 20 20 20 20 89 56 30 32 20 D9 02
          0x50: 40 C1 C6 8A 43 4F 55 49 41 46 55 43 41 42 CF 06
          0x60: A8 9D 21 50 4A 7E 43 00 02 05 01 FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
        Unknown (type 216) Port adapter
        Port adapter is disabled
        Top Assy. Part Number    : 800-04797-01
        Board Revision           : G0
        Deviation Number         : 0-0
        Fab Version              : 05
        PCB Serial Number        : JAD05450AEM
        RMA History              : 00
        Product (FRU) Number     : NM-2FE2W=
          0x00: 04 FF 40 00 D8 41 01 00 C0 46 03 20 00 12 BD 01
          0x10: 42 47 30 80 00 00 00 00 02 05 C1 8B 4A 41 44 30
          0x20: 35 34 35 30 41 45 4D 03 00 81 00 00 00 00 04 00
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
johnlloyd_13
Level 9
Level 9
hi,
you'll need to upgrade the 2811 IOS to 12.4(20)T.
see Table 1A on this link:
http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html
Dear John
Thank's very much yours answer. but which one the IOS file? if I can use that version 2801?
existing ios as follows : System image file is "flash:c2800nm-ipbase-mz.124-3i.bin"
