ADSL Connection dropping regularly
jdinsdale
hi Guys
Ive got a 1721 configured at home on the end of my ADSL line.
I think Ive got it configured ok, but for some reason it drops the DSL connection at least once every hour.
Its doing my head in! Ive tried everything i can think of, but still it drops.
Could it be a faulty WIC?
Heres my config:
version 12.3
service config
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
enable secret ********************
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.7.1
ip dhcp pool HOME
import all
network 192.168.7.0 255.255.255.0
default-router 192.168.7.1
dns-server **************** ****************
lease infinite
no ip ips deny-action ips-interface
ip name-server 212.x.x.7
ip name-server 212.x.x.10
no ftp-server write-enable
interface ATM0
description ADSL line interface
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
description LAN
ip address 192.168.7.1 255.255.255.0
ip access-group 101 in
ip nat inside
ip virtual-reassembly
speed auto
no cdp enable
interface Dialer1
description Connection to ADSL
ip address *********** 255.255.255.252
ip access-group 102 in
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname ****************
ppp chap password ****************
ppp pap sent-username **************** password ****************
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.7.2 3389 80.175.102.137 3389 extendable
ip nat inside source static tcp 192.168.7.2 29310 80.175.102.137 29310 extendable
ip nat inside source static udp 192.168.7.2 29310 80.175.102.137 29310 extendable
access-list 100 deny ip any any
access-list 101 permit ip 192.168.7.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
end
wong34539
Level 6
Level 6
Kindly do a bebug of the ATM interface
Disconnecting the 'ring' wire in the phone socket may help sometime. It can be result from some important misconfiguration in your own network.
If you want to know more please click Below URL:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804fca74.html
Thanks for your reply.
I am getting this in my logs:
ILMI(ATM0): Sending ilmiColdStart trap
ILMI(ATM0): No ILMI VC found
ILMI: Encapsulation error on o/g ILMI Pdu
(ATM0)
Unable to Send Pdu out
