Advice regarding Packet Tracer ACLs
Jonathan Riley
Hi all,
I am working on a packet tracer network for a college assignment.  I have 3 networks, each with 3 VLANs on, 1 Employee wired, 1 Employee Wireless and 1 Guest Wireless.
The network is configured to use routing on a stick, I have a DHCP server on one of the LANs with pools configured for each VLAN. On the sub-interfaces of each router I have configured the ip helper-address, all works perfectly, hosts on each VLAN are obtaining IP addresses as per their VLAN pool. I now want to create an ACL that will allow hosts on the guest VLAN to obtain an IP address and that is all, no pinging hosts on other VLANs. I have tried different ACLs, all with no success, an example of them is shown below:
The VLAN I want to filter is 174, network address 172.40.174.0/26, the DHCP Server is on VLAN 30, IP address 172.40.52.254
First attempt was
  • permit udp 172.40.174.0 0.0.0.63 host 172.40.52.254 eq bootps
  • permit udp 172.40.174.0 0.0.0.63 host 172.40.52.254 eq bootpc
Then I tried
  • permit udp any host 172.40.52.254 eq bootps
  • permit udp any host 172.40.52.254 eq bootpc
Each time the packet is stopped at the router, in simulation mode the packet turns red and clicking on it shows "1. The device sends back an ICMP Administratively Prohibited Unreachable message.", I have tried permitting icmp in the hope that would work but it didn't. My lecturer couldn't figure it out either
I have applied the access group to the interface inbound to filter packets before they cross the network
Any ideas?
Thanks in advance
Jon
Jon Marshall
Jon
The issue is that the DHCP request from the client is a broadcast ie. it is not the DHCP server IP.
So you need to modify your acl. I was recently involved in a similar thread where i suggested an entry which didn't seem to work and the OP suggested different entries which did.
However he had other DHCP issues going on so it's not clear which worked and which didn't.
Have a read of that thread and just try them out  -
https://supportforums.cisco.com/discussion/12375666/router-not-issusing-dhcp-leases
Jon
Jon Marshall
Jon
Jon
Thank you Jon,
The two entries in the thread you advised me to read worked first time. And annoyingly, I wasn't far off with my own entries.
Thanks again, and have a god Christmas and New Year
Jon
