Highlighted
Beginner
After reload 2 cellular of 4 work
Good day!
I've met with unexpected problem - i have Cisco 2851 in which 4 cellular is installed. They both were adjusted through Dialers.
The problem is that after reloading the first two cellulars (cellular 0/0/0 and cellular 0/1/0. А) switch on but the rest two don't switch on.
In debug message:
Attempting async line dialer script
Dialing using Modem script: mts & System script: none
CHAT0/3/0: process started
CHAT0/3/0: Asserting DTR
CHAT0/3/0: Chat script mts started
CHAT0/3/0: Chat script mts finished, status = Connection timed out; remote host not responding
After having executed the 'test cellular x/x/x modem-power-cycle' command an interface switches on and starts working stable and uninterruptible.
Does anybody met with such problem and maybe has an idea how to solve it?
P.S.  each dialer has its own dialer pool and dialer-group.
P.P.S. here is a  chunk of config
interface Cellular0/0/0
ip unnumbered Dialer3
ip mtu 1476
ip nat outside
ip virtual-reassembly in
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 3
dialer-group 3
async mode interactive
ppp chap hostname beeline
ppp chap password 7 0509030A2D45400C
ppp ipcp dns request
interface Cellular0/1/0
ip unnumbered Dialer4
ip mtu 1476
ip nat outside
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 4
dialer-group 4
interface Cellular0/2/0
ip unnumbered Dialer1
ip nat outside
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 1
dialer-group 2
ppp chap hostname gdata
ppp chap password 7 03035F0A120E
interface Cellular0/3/0
ip unnumbered Dialer2
ip mtu 1476
ip nat outside
encapsulation ppp
load-interval 30
dialer in-band
dialer pool-member 2
dialer-group 1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0 either
dialer string MEG
dialer persistent delay initial 2
dialer-group 2
no cdp enable
interface Dialer2
ip mtu 1476
ip nat outside
ip inspect INSPECT_OUT out
encapsulation ppp
dialer pool 2
dialer string MTS
dialer-group 1
ppp chap password 7 06040A244047071C
no cdp enable
interface Dialer3
ip mtu 1476
ip nat outside
encapsulation ppp
dialer pool 3
dialer string MTS
dialer persistent delay initial 3
dialer-group 3
no cdp enable
interface Dialer4
ip mtu 1476
ip nat outside
encapsulation ppp
dialer pool 4
dialer string MTS
dialer persistent delay initial 4
dialer-group 4
no cdp enable
Everyone's tags (3)
5 REPLIES 5
Highlighted
Hall of Fame Master
Re: After reload 2 cellular of 4 work
You might want to move your post to the LAN WAN forum.
https://supportforums.cisco.com/community/netpro/network-infrastructure/switching
-Scott
Highlighted
Beginner
May be. I don't know where it is correct to place this subject.
Highlighted
Hall of Fame Master
Place it on that forum I listed.
-Scott
Highlighted
Beginner
done =)
Highlighted
Beginner
Really nobody knows in what a problem?
Content for Community-Ad
