11-25-2010 03:09 AM - edited 03-06-2019 02:12 PM
Hello All
I have the following configured on a 3750 stack
mls qos aggregate-policer slowdownagg 2000000 78125 exceed-action drop
class-map match-any slowdown
match access-group name slowthese
policy-map slowdown
class slowdown
police aggregate slowdownagg
ip access-list extended slowthese
deny ip 10.145.74.0 0.0.0.255 10.144.210.0 0.0.0.64
deny ip 10.145.75.0 0.0.0.255 10.144.210.0 0.0.0.64
deny ip 10.145.108.0 0.0.0.255 10.144.210.0 0.0.0.64
deny ip 10.145.127.0 0.0.0.255 10.144.210.0 0.0.0.64
deny ip 10.144.210.0 0.0.0.64 10.145.74.0 0.0.0.255
deny ip 10.144.210.0 0.0.0.64 10.145.75.0 0.0.0.255
deny ip 10.144.210.0 0.0.0.64 10.145.108.0 0.0.0.255
deny ip 10.144.210.0 0.0.0.64 10.145.127.0 0.0.0.255
permit tcp any any eq 1352
permit tcp any any eq 8080
deny ip any any
the service-policy is on the UPLINK Trunks (Etherchannel Trunks)
the deny should allow certain subnets to run at full speed on all ports
the permit is showing then that all orhter subnets need to be limited
and although traffic is running that should be caught by the ACL in the Class-Map nothing is being seen........
Switch#sho policy-map interface gi1/0/25 input
GigabitEthernet1/0/25
Service-policy input: slowdown
Class-map: slowdown (match-any)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group name slowthese
0 packets, 0 bytes
rate 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
where am I going wrong ?
Config from this port is......
Current configuration : 182 bytes
interface GigabitEthernet1/0/25
description Etherchannel Trunk
switchport mode trunk
channel-group 1 mode active
service-policy input slowdown
end
Solved! Go to Solution.
11-25-2010 03:26 AM
Fraser
You are not necessarily doing anything wrong. There is a well know issue with "sh policy-map" on the 3560/3750 ie. it doesn't work so you can't rely on it to give you any statistics.
Best you can get on these switches is "sh mls qos interface
Jon
11-25-2010 03:26 AM
Fraser
Jon
11-25-2010 03:43 AM
Thanks John for your fast reply.....
I take it this is what you mean....( the last line)
DESTR01XGW001#sho mls qos int gi1/0/25 statistics
dscp: incoming
0 - 4 : 1182350562 0 0 0 19
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 84546568
25 - 29 : 0 32 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 317527738 0 218064 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 1851694010 0 0 0 139
5 - 9 : 0 0 0 0 0
10 - 14 : 30975 0 24 0 0
15 - 19 : 0 0 0 3 0
20 - 24 : 0 0 0 0 24125
25 - 29 : 0 2760 0 0 0
30 - 34 : 364611 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 91 0 0 0 0
45 - 49 : 0 7799002 0 24171450 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 343523 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 1220437451 0 0 79763125 0
5 - 7 : 293958384 217744 16833
cos: outgoing
0 - 4 : 1913100214 0 0 19960 0
5 - 7 : 8787715 4741 36260
Policer: Inprofile: 70493 OutofProfile: 56
11-25-2010 04:04 AM
Fraser
Yes, this shows that policing is actually occuring regardless of what the policy-map says.
Jon
11-25-2010 06:48 AM
Thanks a lot Jon.
I just need to get my sums right now for the Burst rate.......hmmm....where is that PDF again.... :-)
