Community Helping Community
124
Beginner
Any way to check per slot bandwidth on 4500, 6500?
Hello.
One question.
Is there command that shows per slot bandwidth on CLI??
4507 + Sup 7-E supports 48Gbps per slot.
Can i issue see it on CLI??? what about 6500?
Thank you in advance  ; )
1 ACCEPTED SOLUTION
Hall of Fame Guru
I'm not sure about the 4500 -
I'm not sure about the 4500 - I don't have one to check on right now.
On the 6500 you should be able to use "show fabric status". Reference.
1 REPLY 1
Hall of Fame Guru
Content for Community-Ad
