Anyway to redistribute OSPFv3 into BGP ipv6 AF
TisTos
Is there anyway to redistribute OSPFv3 into BGP ipv6 AF ?
I'm trying it into CSR1000v :
NETERO-R1(config)#router ospfv3 6
NETERO-R1(config-router)#router-id 6.6.6.6
NETERO-R1(config)#router bgp 22
NETERO-R1(config-router)#address-family ipv6
NETERO-R1(config-router-af)#redistribute ?
application Application Protocol
bgp Border Gateway Protocol (BGP)
connected Connected Routes
eigrp Enhanced Interior Gateway Routing Protocol (EIGRP)
isis ISO IS-IS
lisp Locator ID Separation Protocol (LISP)
nd Neighbor Discovery
ospf Open Shortest Path First (OSPF)
rip IPv6 Routing Information Protocol (RIPv6)
static Static Routes
Seems to be not available ?
Mehdi.
Mark Malone
Hey it does not show as ospfv3 under the redistribute command under af ipv6 it only shows as opsf but its still correct
It will look like  this
address-family ipv6
  neighbor 3030:1:1:1::11 activate
  network 5050:55:55:55::55/128
  redistribute connected
  redistribute ospf 1 match internal external 1 external 2
http://www.cisco.com/c/en/us/support/docs/ip/ip-version-6-ipv6/113453-redis-ospfv3-bgp-00.html
Mark Malone
address-family ipv6
Hey, I learned hard way that
router bgp XXX
add ipv6
redistribute ospf match INTERNAL EXTERNAL include-connected
... is really required there otherwise you are going to troubleshoot why the prefixes are in OSPF database and not in BGP table .
