10-20-2010 02:50 AM - edited 03-06-2019 01:37 PM
Hello Community,
I have created a pbr route-map and i want to apply this interface vlan
But when goes ot interface vlan I dont see the option
ip policy route-map PBR
It says unrecognized command
I dont know whats the issue. Can someon help ?
Thanking in advance
10-20-2010 07:15 AM
hello,
in order to be able to configure PBR on the 3560, you need to configure SDm prefer routing template.
Fred
10-20-2010 07:43 AM
Hi Fred,
I enabled sdm prefer but still the command is not working
Here is the output of sh sdm prefer after reload
ALE-COLLEGE-CORE-SW#sh sdm prefer
The current template is "desktop default" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 6K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 8K
number of directly-connected IPv4 hosts: 6K
number of indirect IPv4 routes: 2K
number of IPv4 policy based routing aces: 0
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
Thank you for your help.
10-20-2010 07:49 AM
Apparently, the sdm profile is "desktop default". Did you use "sdm prefer routing", save the config and then reload ?
Fred
10-20-2010 08:36 AM
Yes I tried that but still the same.
I may be related to IOS version because currently it is not ipbase ios.
10-20-2010 09:20 AM
Can you paste the output of "show ver" ?
Fred
10-20-2010 09:45 AM
Hi fred,
Here is the output
Cisco IOS Software, C3560E Software (C3560E-UNIVERSAL-M), Version 12.2(50)SE3,
ELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 05:57 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02400000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(44r)SE2, RELEASE SOF
ARE (fc1)
MALE-COLLEGE-CORE-SW uptime is 41 minutes
System image file is "flash:/c3560e-universal-mz.122-50.SE3/c3560e-universal-m
122-50.SE3.bin"
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560E-12SD (PowerPC405) processor (revision A0) with 262144K bytes o
memory.
Processor board ID FDO1341V01L
Last reset from power-on
11 Virtual Ethernet interfaces
1 FastEthernet interface
16 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:26:0B:35:C8:00
Motherboard assembly number : 73-11215-08
Motherboard serial number : FDO13410P57
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3560E-12SD-S
Daughterboard assembly number : 800-28590-01
Daughterboard serial number : FDO13370GBE
System serial number : FDO1341V01L
Top Assembly Part Number : 800-29161-01
Top Assembly Revision Number : D0
Version ID : V01
CLEI Code Number : COMU510ARA
Hardware Board Revision Number : 0x08
Switch Ports Model SW Version SW Image
* 1 18 WS-C3560E-12SD 12.2(50)SE3 C3560E-UNIVERSAL-M
Configuration register is 0xF
10-20-2010 10:27 AM
According to the following URL:
"The IP Base license offers advanced QoS, rate limiting, ACLs, and basic static and Routing Information Protocol (RIP) routing functions. The IP Services license provides a richer set of enterprise-class features, including advanced hardware-based IPv6 unicast and IPv6 Multicast routing as well as policy-based routing (PBR)."
According to your show ver, you only have the IP base license and will have to upgrade your license.
Fred
10-20-2010 10:37 AM
So fred what can i do now, i cannot upgrade the license
in the current situation
10-20-2010 10:42 AM
Hi fred
by the way I am able to creat route map on the switch but i am not able to apply on vlan interfa
ce
10-20-2010 11:10 AM
The problem here is not the absence of the CLI but the fact the space allocated for the different features in the TCAM is based on the sdm configuration.
In the document I gave your in my initial answer shows that for PBR, in the default template, there is no resource allocated.
Apart changing the license to be able to configure the sdm routing prefer, you will not be able to use PBR unfortunately.
Fred
10-22-2010 08:35 AM
It looks like there is no way to aplly route-map with my current model.
Can I use static route for a specifice to route the traffic to another vlan ?
Is is possible ?
Samir
10-22-2010 10:13 AM
Is is possible ?
Samir
Samir
With a static route you cannot specify the source IPs ie. you only say to get to this destination go there. So you cannot do the equivalent of PBR. If you want to send traffic based on it's source IP you need PBR.
Jon
10-22-2010 10:27 AM
Static routes will not allow you to do the same as PBR. Now, if you want to have a specific host to be reachable via another interface than the one your routing gives you, you can play with static host routes for instance. Though, all traffic for that particular host will follow the static and you cannot differentiate it based on source IP for instance.
Fred
10-22-2010 11:07 AM
Hi Fred and Jon,
For instance i want to say that ip route 10.1.100.0 255.255.255.0 10.1.101.1
Meaning that route vlan 100 traffic to that destination ip i,e adsl router interface ip.
Can i do this ?
