Applying QoS settings to inbound layer 2 traffic
netopia
I have a 3750G switch (IOS 12.2).  I've got a server on a port off of this switch that sends out multicast traffic, but does not apply any QoS settings.  I'm trying to figure out how to add CoS or DSCP to all inbound traffic on the port (which is on a vlan operating at layer 2 only).  The documents I have found seem to assume that the inbound traffic already has some settings to trust.
-Ben Brown
Hello Ben,
In case the server is sending already marked traffic and you are agree with it you can preserve it with the following interface level command:
# mls qos trust dscp
In case you want to remark the traffic or apply a particular DSCP/CoS there is a few ways to do so, it would be helpful to get a port configuration in order to understand the way it's configured.
Thank you
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
Unfortunately, the traffic is not in any way marked coming out of the server.
My current port configuration is dead stupid:
interface GigabitEthernet1/0/22
description mediaroom server
switchport access vlan 101
switchport mode access
switchport nonegotiate
-Ben
Hello Ben,
There is a few ways to mark incoming traffic in your case. I would suggest you to evalute the following two:
In order to modify QoS settings you should enable "mls qos" globally on a switch
mls qos
1. Default CoS for all incoming traffic
  mls qos cos
  mls qos trust cos
In this case all untagged traffic will be marked with for internal processing and DSCP will be rewritten accordingly to cos-dscp mutation map, from the table DSCP value which corresponds to configured CoS will be used You can check the map with the following command:
show mls qos maps cos-dscp
2. Marking accordingly to configured policy-map
! Either match only mcast traffic and mark it separately or mark all traffic from server
access-list 100 permit ip any 224.0.0.0 15.255.255.255
class-map CM-MCAST-MEDIAROOM
  match access-group 100
policy-map PM-MARK-MEDIAROOM
  class CM-MCAST-MEDIAROOM
    set dscp
  service-policy input PM-MARK-MEDIAROOM
2a. Mark all incoming traffic
  class class-default
    set dscp
Best regards,
Dmitry Skotnikov
I will give it a try.  Thanks.
