Archive Command - Sequencing
Tormod Macleod
Level 2
Level 2
Hi folks,
I'm using the archive command to backup the config of a switch to a tftp server every time a user enters the write memory command. The problem that I have is that a sequence number is automatically added to the end of the file name. The commands I'm using are below. I've also tried removing the $h and specifying a file name but to no avail.
The only 2 switches I can find in documentation are $h and $t. The first makes the filename the name of the switch, the second timestamps the file name. I'm hoping there's one that stops the sequence number being added to the file name.
archive
path tftp://192.168.22.22/Cisco/$h
write-memory
Thanks for looking
milan.kulik
Level 11
Level 11
archive
maximum 1
might bring you what you want - just one (latest) copy of each device configuration.
But you'd lose many advantages, see
http://www.cisco.com/en/US/customer/docs/ios/fundamentals/configuration/guide/cf_config-rollback_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1051953
HTH,
Milan
