Join Customer Connection to register!
193
amirkh1566
Beginner
Are there any difference between products made in 2012 or 2013?
Hi;
I want to know any difference on just hardware between products in 2012 & 2013 as bellow :
ws-c3750X-24T-S
ws-c3750X-24T-E
ws-c3750X-12S-S
1 ACCEPTED SOLUTION
Leo Laohoo
VIP Community Legend
No physical differences in all of them, regardless when it was built.
Same color.  Same weight.  Components are the same.  Same functions.
If you have switches recently received that, for example, has a different set of s_crews then there's a high chance you're looking at a counterfeit.  Unless you get refurbished or RMA-ed, the fonts to the serial numbers should not change much.
5 REPLIES 5
Leo Laohoo
WS-C3750X-24T-S
Stackable 24 10/100/1000 Ethernet ports, with 350W AC power supply 1 RU, non-PoE, IP Base feature set
WS-C3750X-24T-E
Stackable 24 10/100/1000 Ethernet ports, with 350W AC power supply 1 RU, non-PoE, IP Services feature set
WS-C3750X-12S-S
Stackable 12 GE SFP Ethernet ports, with 350W AC power supply 1 RU, non-PoE, IP Base feature set
Thansk Leo,
But I want to know about comparing these switches produced in 2012 with 2013.
IOS versions are same on all of them.
Are there difference between these switches that produced in 2012 with  these switches  produced in 2013? ( year of produced is important)
Leo Laohoo
amirkh1566
Beginner
Thanks again
Leo Laohoo
Thank you for taking the time to rate our posts.  laugh
