arp
carl_townshend
hi all, Does arp work at layer 2 of the osi model ? or layer 3 also ?
Aaron Harrison
ARP protocol finds layer 2 (MAC) addresses from Layer 3 addresses - so I guess it's a layer 3 protocol that allows determination of addresses used at layer 2...
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
scottmac
Level 10
Level 10
ARP is part of the TCP/IP suite. Which means it's really a layer 3/4 protocol. Arp is sort of an 'in-between' like ICMP; it's not really a TCP thing, it's just one of the protocols in the suite.
As mentioned, it for finding the L2/L# address association.
FWIW
Scott
ARP its a L3 protocol since it request for an phisical address based on an IP address.
It works in layer 3.
PAWP
