AS5350 E1 R2
bden
Misters, prompt that it is necessary to adjust at AS5350. A problem following: is AS5350 and automatic telephone exchange Alcatel which are joined on stream E1 to signal system R2. There is a problem when AS5350 does not understand, that the client has hanged up. I shall tell more particularly: the client has hanged up, and sluice AS5350 does not understand, that it is necessary to tear connection. We have lag of lines in a stream. Now it is adjusted so:
controller E1 1
framing NO-CRC4
clock source line secondary 1
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country easteurope
dnis-complete
timer interdigit incoming 3000
How will get rid of it?
wong34539
Level 6
Level 6
This command is used when AS5400 with E1/R2 lines might periodically have an increasing number of timeslots which go out of service.clear the blocked E1 timeslots on the E1/R2 switch
