05-07-2010 11:39 AM - edited 03-06-2019 10:59 AM
I have configured our ASA with an interface for the internal network (BeneNetwork) and our wireless solution (WLAN) everything is working OK the wireless clients receive all configurations from DHCP and can ping the the gateway address., but does not have communication to BeneNetwork.
Attached is my configuration for review,
Thank you,
ASA Version 8.2(2)
hostname remote
domain-name benetech.org
enable password sh3Lt8bNBi5BmLfG encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 172.16.20.100 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.240
interface Vlan3
description WLAN
nameif WLAN
security-level 100
ip address 172.16.30.100 255.255.255.0
interface Vlan4
description Benetech Network
nameif BeneNetwork
security-level 100
ip address 10.10.220.100 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 4
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
switchport access vlan 3
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu WLAN 1500
mtu BeneNetwork 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any BeneNetwork
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (WLAN) 1 0.0.0.0 0.0.0.0
nat (BeneNetwork) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 10.10.220.23
dhcpd domain benetech.local
dhcpd auto_config outside
dhcpd option 3 ip 172.16.30.100
dhcpd address 172.16.30.150-172.16.30.200 WLAN
dhcpd enable WLAN
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:c40d69de4ce1b0e912f403ec6902c2b2
: end
Solved! Go to Solution.
05-07-2010 04:23 PM
I took out the nat (beneNetwork) 1 0.0.0.0 0.0.0.0 and now not getting the error
05-07-2010 04:39 PM
After some changes here is what I am receiving:
Built inbound UDP connection 4325 for WLAN:172.16.30.171/53558 (172.16.30.171/53558) to BeneNetwork:10.10.220.23/53 (10.10.220.23/53)
Teardown UDP connection 4271 for WLAN:172.16.30.171/62768 to BeneNetwork:10.10.220.23/53 duration 0:02:03 bytes 76
05-07-2010 04:44 PM
05-07-2010 08:42 PM
Packet Tracer Results
Result:
input-interface: WLAN
input-status: up
input-line-status: up
output-interface: NP Identity Ifc
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Result:
input-interface: BeneNetwork
input-status: up
output-status: up
Action: drop
05-08-2010 01:56 PM
Stephen,
There seems to be an ACL dropping the packets (which I don't see from your original configuration).
Can you post:
sh run access-list
sh run access-group
Federico.
05-08-2010 05:19 PM
Yes I found out that the ASA has a built-in implicit rule which deny's all traffic, you then need to create ACL's to create passage past the implicit rule. I am having trouble doing this. Any suggestions?
This what I get with the sh run access-list, the sh run access-group returns nothing.
access-list WLAN_nat0_outbound extended permit ip any any
Thank you Sir,
Stephen
05-08-2010 05:34 PM
Stephen,
In theory since you have both interfaces we are dealing with, configured with the same security level (level 100), there's no need for an ACL to permit the traffic to flow.
However, the packet-tracer seems to report an ACL dropping problem.
What if you enable ACLs to permit the traffic.
i.e.
access-list WLAN permit ip any any
access-list Benetech permit ip any any
access-group WLAN in interface WLAN
access-group Benetech in interface Benetech
Obviously, the above ACLs are a security gap, I just want to see if by permitting all traffic explicity with the ACLs, we get a different result from the packet tracer.
Federico.
05-11-2010 09:36 AM
I added the lines you suggested IP packets are still being droped
here is my current configuration:
ASA Version 8.2(2)
hostname remote
names
interface Vlan2
nameif outside
security-level 0
ip address 66.201.46.94 255.255.255.240
interface Vlan3
description WLAN
nameif WLAN
security-level 100
interface Vlan4
nameif BeneNetwork
security-level 100
ftp mode passive
access-list WLAN extended permit ip any any
access-list BeneNetwork extended permit ip any any
pager lines 24
logging enable
mtu outside 1500
mtu WLAN 1500
no failover
icmp permit any WLAN
arp timeout 14400
nat (WLAN) 0 access-list WLAN_nat0_outbound
static (WLAN,BeneNetwork) 172.16.30.0 172.16.30.0 netmask 255.255.255.0
access-group BeneNetwork in interface BeneNetwork
route outside 0.0.0.0 0.0.0.0 66.201.46.81 1
http server enable
http 10.10.220.0 255.255.255.0 BeneNetwork
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable WLAN
webvpn
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
Cryptochecksum:b63aa441f064846d661588820dfdb228
05-11-2010 09:46 AM
here is the result of a packet trace:
packet-tracer input WLAN tcp 172.16.30.100 53 10.10.220.23 53
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 10.10.220.0 255.255.255.0 BeneNetwork
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Forward Flow based lookup yields rule:
in id=0xd8a8b300, priority=500, domain=permit, deny=true
hits=4, user_data=0x6, cs_id=0x0, reverse, flags=0x0, protocol=0
src ip=172.16.30.100, mask=255.255.255.255, port=0
dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Result:
input-status: up
output-interface: BeneNetwork
output-status: up
Action: drop
05-11-2010 10:26 AM
Stephen,
I would do this:
interface Vlan4
security level 99
no access-list WLAN_nat0_outbound extended permit ip any any
no nat (WLAN) 0 access-list WLAN_nat0_outbound
no nat (WLAN) 1 0.0.0.0 0.0.0.0
With the changes above, we're going to have only this configuration:
interface Vlan3
description WLAN
nameif WLAN
security-level 100
interface Vlan4
nameif BeneNetwork
security-level 99
Try communication between the networks.
Federico.
05-11-2010 10:49 AM
Still having dropped packets, from the wireless client I can ping the gateway IP address 172.16.30.100 but not anything past there.
05-11-2010 11:10 AM
Post this commands after the last changes:
sh run int vlan 3
sh run int vlan 4
sh run nat
sh run static
sh run global
sh run access-list
sh run access-group
Federico.
05-11-2010 11:18 AM
Thank you for your help with this issue, here what you have requested.
interface Vlan3
description WLAN
nameif WLAN
security-level 100
interface Vlan4
nameif BeneNetwork
security-level 99
sh run nat – returns nothing
05-11-2010 11:31 AM
Ok,
You should be able from a device off the WLAN interface to communicate with a device off the Benetech interface.
If it does not work, let me know the source IP and the destination IP of the connection you're trying.
Federico.
05-11-2010 11:41 AM
No I cannot, the IP of the laptop is 172.16.30.190 the IP I am attempting to connect to is 10.10.220.23. I can ping the gateway 172.16.30.100 but not anything else past this IP.
