ASA 5505 - QoS and CBWFQ
mackeyuk
Beginner
Beginner
Hello All,
I have an ASA 5505 firewall that I want to use to share an office internet connection fairly.
I need to create VLANs for office1 and office2.   office1 and office2 are separate companies within the building so they should not be able to communicate with each other, each office will be on different subnets.
When office1 is using the internet they should be able to utilise 100% of the bandwidth available.  However if office2 is sharing the connection the bandwidth should be spilt fairly 50/50.
I would also like to be able to prioritise bandwidth for certain types of traffic say SMTP for example.
Can anyone give me some examples of how to implement this?  The information on QoS is mind boggling.
Many thanks,
Mac.
Collin Clark
Advisor
Advisor
A thing to note is that QoS on the ASA is not as feature rich as a router or switch. That being said here's a link that should help.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml
Hope it helps.
Hi Colin,
Many thanks for the pointer, the article was a good read.
However I have tried using policing to limit the bandwidth of 1 host pc as a test and I cant seem to get it working.
I am using the 'crew' access list to match 192.168.100.3.
Here is my running config:
ASA Version 8.0(2)
hostname ciscoasa
enable password bkdbRfYTlRx94nOD encrypted
names
interface Vlan1
description admin-network
nameif admin
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 5
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
access-list admin extended permit ip host 192.168.100.2 any
access-list crew extended permit ip host 192.168.100.3 any
pager lines 24
logging asdm informational
mtu admin 1500
mtu outside 1500
mtu crew 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-611.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (admin) 1 0.0.0.0 0.0.0.0
nat (crew) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.100.0 255.255.255.0 admin
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.100.2-192.168.100.33 admin
dhcpd dns 208.67.222.222 208.67.220.220 interface admin
dhcpd enable admin
threat-detection basic-threat
threat-detection statistics access-list
class-map match-crew
match access-list crew
class-map inspection_default
match default-inspection-traffic
class-map match-admin
match access-list admin
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
policy-map qos
class match-crew
  police output 128000
  police input 128000
service-policy qos global
prompt hostname context
: end
Recognize Your Peers
