ASA 5520 install network Module
Hi All
I have one ASA 5520 Version 7.2(2)22 with vpn plus license, the question is if i could install a 4-port gigabit ethernet security services module without problems?
here the license of my ASA 5520
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs               : 150
Inside Hosts                : Unlimited
Failover                    : Active/Active
VPN-DES                     : Enabled
VPN-3DES-AES                : Enabled
Security Contexts           : 2
GTP/GPRS                    : Disabled
VPN Peers                   : 750
WebVPN Peers                : 2
This platform has an ASA 5520 VPN Plus license.
Attached the 4-port gigabit ethernet module SSM-4GE
-Regards.
mvsheik123
Level 7
Level 7
Yes. There should n't be any issues. One thing- you need to power down ASA to install the module. These are not OIR compatable.
hth
MS
mvsheik123
Level 7
Level 7
hth
MS
