Ask the Expert: Catalyst 2960-X and 2960-XR Switches Overview, Configuration, and Troubleshooting
Monica Lluis
Level 9
Level 9
The Cisco Catalyst 2960-X models provide Layer 2 switching and have one fixed power supply with an external redundant power supply. They provide 24 or 48 Gigabit Ethernet wire rate ports, PoE/PoE+ support, and four 1G Small Form-Factor Pluggable (SFP) or two 10G SFP+ uplinks. With FlexStack-Plus technology, the Cisco Catalyst 2960-X switches can be stacked up to 8 members with up to 80 Gbps stacking capacity for high scalability. During this presentations, Roopa R. will talk about the architecture and stacking of the Cisco Catalyst 2960-X and 2960-XR Series Switches. She will also cover packet walk through, overview, configuration and troubleshooting of various features on these switches like QOS, Security, Netflow, PnP etc.
You can ask questions about the architecture and stacking of the Cisco Catalyst 2960-X and 2960-XR Series Switches. She will also cover packet walk through, overview, configuration and troubleshooting of various features on these switches like QOS, Security, Netflow, PnP etc.
To participate in this event, please use the Reply Button to ask your question.
Ask questions from Tuesday May 10 to Friday May 20, 2016
Featured Experts
Santhosh Chidri Nagaraj is a Technical Leader in Enterprise Access Switching group at Cisco. He is an expert on Forwarding – 802.1X, Security, Cisco Identity, AAA, Radius, Cisco TrustSec technologies and products. Santhosh holds a Bachelor’s Degree in Mechanical Engineering from Bapuji Institute of Engineering and Technology and an MBA Kuvempu University in India.  He has 17 years of experience in IT and has been working at Cisco for 5.5 years. Prior to Cisco he worked at Texas Instruments India Pvt Limited, Novell, HCL Technologies.
Prabha Ganesan is a Software Engineer in Enterprise Access Switching group at Cisco. She is an expert on Forwarding – Platform, Forwarding L3, L2, ASIC Validation as well as Catalyst Switches technologies and products. Prabha holds a Bachelor’s Degree in B.E Computer Science and Engineering from Anna University in India.  She has 10 years of experience in IT and has been working at Cisco for 6.5 years. Prior to Cisco she worked at Computer Sciences Corporation.
Find other  https://supportforums.cisco.com/expert-corner/events.
** Ratings Encourage Participation! **
Please be sure to rate the Answers to Questions
https://supportforums.cisco.com/expert-corner/events ">https://supportforums.cisco.com/expert-corner/events.
We look forward to your participation. This event is open to all, including partners. Please Share this event in your social channels. Have a technical question? Get answers here before opening a TAC case by visiting the Cisco Support Community.
I hope you and your love ones are safe and healthy
Monica Lluis
Community Manager Lead
2 Accepted Solutions
Jessica Deaken
Hello. I have a quick question.
What is the maximum number of MAC addresses that can be learned on the 2960X/XR?
- Jessica
2960x and 2960XR cannot be stacked, as they both have different license
51 Replies 51
Jessica Deaken
- Jessica
16K mac address is supported in 2960x
Jessica, it also depends upon the SDM template chosen. As Prabha mentioned 16K is the max and this is with the lanbase-default template. Take a look at the link below for details on the SDM template and the number of MAC addresses etc that each one supports.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-2_2_e/system_manage/configuration_guide/b_sm_1522e_2960x_cg/b_sm_152ex_2960-x_cg_chapter_0100.pdf
I was upgrading the firmware of one of our 2960-X Switches to c2960x-universalk9-tar.152-2.E3. When the firmware was updated the switch rebooted and was coming up with "BOOT FAIL".
I am not able to get to ROMmon. It has no reaction if I press the Mode button at start or trying to send a break in Terminal (HyperTerm and Putty), also a CTRL+C, CTRL+Break or any other key combinations are not helping.
BTW: The Switch is not a stack-member
Can you share the PID of the switch you are trying to boot?
Roopa
Not at the moment. I don't have physical access to it until Tuesday.
Can you also share the entire boot process log when you try it the next time. I only see the BOOT FAIL logs in the attached JPG.
Roopa
What you see is the entire boot process log. It only sends BOOT FAIL, nothing else.
I have got the same issue.
Does the 2960-X support:
sdm prefer lanbase routing
This to be able to use the switch as a simple L3 switch like the old 2960 switches.
Yes it does support the lanbase routing template similar to the other 2960 switches with support for 16 Static routes for IPV4 and IPV6.
HTH,
Roopa
Thanks Roopa.
Best Regards,
Henk
Monica Lluis
Level 9
Level 9
Hello Prabha and Santhosh,
Thank you for all your work answering questions during the live webcast. There are few questions that were not answered. I will post them in this thread.
Monica Lluis
If I have stacked of four switches and switch one is configured with priority 15 (Master switch), which switch should be configured as back up master (priority 10) as a best practice?
Monica Lluis
