Ask the Expert: Catalyst 2960-X and 2960-XR Switches Overview, Configuration, and Troubleshooting
Monica Lluis
Level 9
Level 9
The Cisco Catalyst 2960-X models provide Layer 2 switching and have one fixed power supply with an external redundant power supply. They provide 24 or 48 Gigabit Ethernet wire rate ports, PoE/PoE+ support, and four 1G Small Form-Factor Pluggable (SFP) or two 10G SFP+ uplinks. With FlexStack-Plus technology, the Cisco Catalyst 2960-X switches can be stacked up to 8 members with up to 80 Gbps stacking capacity for high scalability. During this presentations, Roopa R. will talk about the architecture and stacking of the Cisco Catalyst 2960-X and 2960-XR Series Switches. She will also cover packet walk through, overview, configuration and troubleshooting of various features on these switches like QOS, Security, Netflow, PnP etc.
You can ask questions about the architecture and stacking of the Cisco Catalyst 2960-X and 2960-XR Series Switches. She will also cover packet walk through, overview, configuration and troubleshooting of various features on these switches like QOS, Security, Netflow, PnP etc.
To participate in this event, please use the Reply Button to ask your question.
Ask questions from Tuesday May 10 to Friday May 20, 2016
Featured Experts
Santhosh Chidri Nagaraj is a Technical Leader in Enterprise Access Switching group at Cisco. He is an expert on Forwarding – 802.1X, Security, Cisco Identity, AAA, Radius, Cisco TrustSec technologies and products. Santhosh holds a Bachelor’s Degree in Mechanical Engineering from Bapuji Institute of Engineering and Technology and an MBA Kuvempu University in India.  He has 17 years of experience in IT and has been working at Cisco for 5.5 years. Prior to Cisco he worked at Texas Instruments India Pvt Limited, Novell, HCL Technologies.
Prabha Ganesan is a Software Engineer in Enterprise Access Switching group at Cisco. She is an expert on Forwarding – Platform, Forwarding L3, L2, ASIC Validation as well as Catalyst Switches technologies and products. Prabha holds a Bachelor’s Degree in B.E Computer Science and Engineering from Anna University in India.  She has 10 years of experience in IT and has been working at Cisco for 6.5 years. Prior to Cisco she worked at Computer Sciences Corporation.
Find other  https://supportforums.cisco.com/expert-corner/events.
** Ratings Encourage Participation! **
Please be sure to rate the Answers to Questions
https://supportforums.cisco.com/expert-corner/events ">https://supportforums.cisco.com/expert-corner/events.
We look forward to your participation. This event is open to all, including partners. Please Share this event in your social channels. Have a technical question? Get answers here before opening a TAC case by visiting the Cisco Support Community.
I hope you and your love ones are safe and healthy
Monica Lluis
Community Manager Lead
51 Replies 51
It can be any priority between 1-15. That should not matter.
Roopa
How the WS-C2960XR-24PD-I can read the teng interfaces , it like 3850 Ten 1/1/1 & Ten 1/1/2 or how it can read it ?
Monica Lluis
Level 9
Level 9
Can we stack a 2960X LAN Base and a 2960XR IP Lite?­
Monica Lluis
2960x and 2960XR cannot be stacked, as they both have different license
Monica Lluis
Level 9
Level 9
 ­I understand this switches can do L3 routing, does it support NAT/PAT?­
Monica Lluis
NAT/PAT is not supported on the switch. The switch only supports basic L3 on 2960XR.
Roopa
Monica Lluis
Level 9
Level 9
Hi, is the netflow lite is built in the switch­?
Monica Lluis
Yes Netflow lite is built in the switch. The hardware is capable of net flow lite.
Roopa
Monica Lluis
Level 9
Level 9
Is there a SW recommendation for 2960-S? If not, why not?­
Monica Lluis
15.2(2)E4 is the recommended release for 2960S
15.0(2)SE9 is the recommended software for 2960S, and not 15.2(2)E4.
Roopa
Monica Lluis
Level 9
Level 9
Suppose if we change the mac address of the device using the MAC spoofing changeR, how the switch will take once it learned the legitimate mac address?
Monica Lluis
To protect against MAC spoofing, there is the feature called IP Source Guard. Please  check the following link for details of the feature. Do get back to us in case of any queries.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swdhcp82.html
Roopa
Monica Lluis
Level 9
Level 9
Is there flexstack power cable capabilty on 2960-XR (as ws-c3850 series)?­
Monica Lluis
2960Xr Flexstack cables are not power capable
