07-25-2017 12:38 AM - edited 03-08-2019 11:27 AM
We have ASR1004, es works till the module SPA-1X10GE-L-V2 not started and gives always following errors.
Error (3) |
CMCC-3-PLIM_STATUSSIP0: cmcc: A PLIM driver informational error RXSPI0 DIP4 Error, block 13 count 7 |
Error (3) |
CMCC-3-PLIM_STATUSSIP0: cmcc: A PLIM driver informational error RXSPI0 DIP4 Error, block 13 count 3d |
Error (3) |
IOSXE_SIP_SPA-3-SPI4_NOTSYNCSIP1/2: SPA-1X10GE-L-V2[1/2]: Can not synchronize SPI4 bus (host: src not in sync, sink not in sync, spa: src in sync, sink in sync). |
Error (3) |
SPA_OIR-3-SPA_POWERED_OFFsubslot 1/2: SPA 1x10GE XFP SPA powered off after 5 failures within 1200 seconds |
Error (3) |
SPA_OIR-3-RECOVERY_RELOADsubslot 1/2: Attempting recovery by reloading SPA |
Error (3) |
Error (3) |
Error (3) |
IOSXE_PEM-3-PEMFAILThe PEM in slot P0 is switched off or encountering a failure condition. |
Error (3) |
Error (3) |
Error (3) |
can someone help us
07-25-2017 01:38 AM
Check your IOS versions and look at bug CSCsv71393
Alex
07-25-2017 02:33 AM
See if you can try the steps suggested here:
https://supportforums.cisco.com/discussion/10929821/spa-4x1fe-tx-v2-out-service-asr1006
