ASR1001-X 10G interface license
kkhee
Hi all,
I have installed the PAK license(FLSA1-BIN-2X10GE) into my ASR1001-X, but when I show license it shows License Count: Non-Counted, I have "no shut" the port but it still shows Non-Counted.
Do I need to reboot the device after installing the PAK license?
#license install flash:JAE21XXXXX_20220228045723950.lic
Installing licenses from "flash:JAE21XXXXX_20220228XXXXXXXX.lic"
Installing...Feature:interface_10g...Successful: Supported
1/1 licenses were successfully installed
0/1 licenses were existing licenses
0/1 licenses were failed to install
Index 33 Feature: interface_10g
                Period left: Life time
                License Type: Permanent
                License State: Active, In Use
                License Priority: Medium
StoreIndex: 2 Feature: interface_10g Version: 1.0
Leo Laohoo
But EULA was not accepted.
Hi Leo,
I know that the EULA needs to be activated because Cisco IOS activates an RTU license when you accept the EULA agreement and the corresponding Cisco IOS functionalities will be available. The RTU license supports the following software features:
*Inter chassis redundancy
*Lawful intercept
*Software redundancy
*IPsec
*Throughput
Please correct me if there is something wrong.
