Asr1006 to cisco 6500
BrianColemangr8
Hope someone can assist.  Setup and interface on spa-10x1ge-v2 interface using a mm sfp.  Connecting to 6500 using same type mm sfp.  Getting a down down on interface.  Setup the 10gig ports on the same equipment and it works fine.  Used the same fiber pair for the 1gig interfaces as I did on the 10gig interfaces.  Also tried no negotiate auto command.  Still get a down down status on 1gig interfaces.  Ideas?  Oh, used the same config on the interface too.
Reza Sharifi
Can you try to swap the fiber strands on one side of the fiber and test again?
Are you using a patch panel or going directly between devices?
Forgot to mention In the original post that I tried that already.  It's going through patch panels, but as I said, I'm using the same fiber in a 10gig link.  Also tried swapping sfp on both ends as well as trying different ports.
