Auto qos error
AYTOIAM2009
I have an access switch C4506. When I try to use "auto qos voip trust" o "auto qos voi cisco-phone" I have the following error:
C4506E-CIBII-MUSEO-4(config-if)#auto qos voip trust
The policy AutoQos-VoIP-Input-Cos-Policy cannot be attached to the interface Gi1/3 since it has 'set' actions. IP Routing and CEF Switching are required for 'set' actions to be effective.Please enable IP routing and CEF switching.
AutoQoS Error: the following generated command was not properly applied:
service-policy input AutoQos-VoIP-Input-Cos-Policy
no service-policy attached to this interface
Class-map AutoQos-VoIP-Bearer-Cos is being used
Class-map AutoQos-VoIP-Control-Cos is being used
Class-map AutoQos-VoIP-Bearer-Dscp is being used
Class-map AutoQos-VoIP-Control-Dscp26 is being used
Class-map AutoQos-VoIP-Control-Dscp24 is being used
Class-map AutoQos-VoIP-Bearer-QosGroup is being used
Class-map AutoQos-VoIP-Control-QosGroup26 is being used
Class-map AutoQos-VoIP-Control-QosGroup24 is being used
AutoQoS Error while generating commands on Gi1/3.
The IOS version is:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-LANBASE-M), Version 12.2(53)SG2, RELEASE SOFTWARE (fc1)
I have tried to find some information in the Software Bug ToolKit but I failed.
Any idea?
Thanks in advanced
John Blakley
Do you have CEF and routing enabled on the switch?
HTH, John *** Please rate all useful posts ***
No, I don't have routing and CEF enabled on the switch.
Why do I have to enable IP routing in a access device?
