auto qos for non cisco ip phones.
themizzz21
A VoIP installation contains Cisco switches and Yealink sip ip phones. Yealink ip phones utilize CDP. When issuing the command <show cdp neighbors detail> the export is the following:
Device ID: T48S001565BD80AF
Entry address(es):
IP address: 10.20.150.34
Platform: T48S, Capabilities: Host Phone
Interface: FastEthernet0/4, Port ID (outgoing port): WAN PORT
Holdtime : 167 sec
Version :
advertisement version: 2
Duplex: full
Power drawn: 14.100 Watts
Management address(es):
T48S is a Yealink ip phone.
We enabled auto QoS but when issuing the command <show policy-map int ...> there are no packets/bytes in the class-maps.
Service-policy input: AUTOQOS-SRND4-CISCOPHONE-POLICY
Class-map: AUTOQOS_VOIP_DATA_CLASS (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef (46)
Class-map: AUTOQOS_VOIP_SIGNAL_CLASS (match-all)
0 packets, 0 bytes
Match: ip dscp cs3 (24)
Class-map: AUTOQOS_DEFAULT_CLASS (match-all)
0 packets, 0 bytes
Match: access-group name AUTOQOS-ACL-DEFAULT
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
5 minute rate 0 bps
Ιs it possible to use those Yealink ip phones as if they are Cisco ip phones and use auto QoS?
Switch version:
Switch   Ports            Model                    SW Version          SW Image
* 1       52     WS-C3560-48PS          12.2(55)SE4    C3560-IPBASEK9-M
Thank you very much.
0 Replies 0
