auto qos voip cisco-phone, does it remark non conforming packets?
pdub206
The 3650 QoS configuration guide I'm reading does not clearly state whether
auto qos cisco-phone
actually remarks non-conforming packets to dscp 0.  For example, if I apply the above configuration to a port that a Cisco phone is not on, will it remark all packets as DSCP 0?
Throwing packets since 2012
Mark Malone
I haven't tested it with non cisco phone using the cisco syntax usually it would be just trust voip instead if non Cisco, but looking at the below its not going to trust it through cdp if its not a Cisco phone so most likely it will be marked back to 0
cisco-phoneWhen you enter the auto qos voip cisco-phone interface  configuration command on a port at the edge of a network that is  connected to a Cisco IP Phone, the switch enables the  conditional-trusted boundary feature. The switch uses the Cisco  Discovery Protocol (CDP) to detect the presence or absence of a Cisco IP  Phone. When a Cisco IP Phone is detected, the ingress classification on  the interface is set to trust the CoS marking of the received packet.  When a Cisco IP Phone is absent, the ingress classification is set to  not trust the CoS (or DSCP) value of any packet.
Mark Malone
