bandwidth rate
swamy105
The following is the Gateway Router external interface counters::::
stEthernet0/1 is up, line protocol is up
Hardware is Gt96k FE, address is 0013.c3c2.6c8b (bia 0013.c3c2.6c8b)
Description: INTERFACE TO CHN_TVM LINK
Internet address is 10.0.0.2/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 5/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:07, output 00:00:00, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/1024/0 (size/max total/threshold/drops)
Conversations 0/2/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 75000 kilobits/sec
30 second input rate 1984000 bits/sec, 308 packets/sec
30 second output rate 757000 bits/sec,
-------------------------------------- 271 packets/sec
7297947 packets input, 2758474231 bytes
Received 1108 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
Please, do look at the input rate and output rate.
My company is having 2Mbps link intranet link , I haven't set any bandwidth on this interface:
My doubt is the total bandwith utlization on the link would be the sum of
out put rate and input rate... OR only output rate,and only input rate... I just completed my CCNA .. I am total confused with this.. I would be grateful ,, If any one can give a reliable answer for that....
scottmac
Level 10
Level 10
The "Bandwidth" statement does not affect the actual throughput, it is there for some routing protocols (like EIGRP and OSPF) to become part of the "best path" determination. Some monitoring and management software will also use that number to establish the 100% baseline.
You can edit that statement for each interface independently. Fast Ethernet will automatically default to 100,000 Kbit (like T1 will default to either 1544K or 1536K depending on the hardware).
The bandwidth provided by the ISP / carrier would be full duplex (usually), so that you are likely getting 2 Meg down as well as 2 meg up (at the same time ... "4 meg" in marketing-speak ;-} )
Re-post if you have any other questions ...
Good Luck
Scott
