03-18-2020 01:22 AM
Our customer has two BE6K servers it is installed CUCM and CUC ,and the customer needed to install Virtual ISE on the same server platform ,can we do it or not?
03-18-2020 01:48 AM
- I wouldn't recommend it as ISE is usually being mission-critical and I would chase separate (hardware) servers.
M.
03-18-2020 07:38 AM
03-18-2020 09:00 AM
- I don't think CISCO would consider this as being supported , but if you need to verify you need to contact them for getting an authoritative answer.
M.
