07-24-2015 02:01 PM - edited 03-08-2019 01:06 AM
I understand that when you insert a service module into a 2921 that you need to configure a IP address to access the sm card.
My question, is the best practice to leave that interface that is created under the router and switch a Layer three 30 bit connection? then just route the SVI's on the switch to the router?
or
To trunk any networks across the interface that is created, with a bunch of encapsulated sub-interfaces?
Solved! Go to Solution.
10-22-2015 10:26 AM
I opened at TACs and cisco instructed the following configuration. The Gi1/0 created when you install the SM is your Layer 3 routed port to the switch and what you use when you session in. We use a 30 bit ip on either side that is not included in the EIGRP. The Gi1/1 is a trunk port used for traffic. The SVI's are created on the ROUTER and then trunk'd across the gi1/1 for the client ports on the switch.
ROUTER#
interface GigabitEthernet1/0
ip address 10.107.10.1 255.255.255.252
interface GigabitEthernet1/1
description internal switch interface connected to Service Module
switchport trunk native vlan 999
switchport mode trunk
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan100
ip address x.x.x.x 255.255.255.240
ip helper-address x.x.x.x
interface Vlan200
ip address x.x.x.x 255.255.255.192
ROUTER# service-module gigabitEthernet 1/0 session
SERVICE_MODULE#
interface GigabitEthernet0/51
interface GigabitEthernet0/52
no switchport
ip address 10.107.10.2 255.255.255.252
07-24-2015 03:30 PM
To access the SM, you create an SVI with an IP address in your management vlan on the SM and than trunk the port between the SM and the router and create sub-interfaces on the router.
10-22-2015 10:26 AM
ROUTER#
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan100
interface Vlan200
SERVICE_MODULE#
no switchport
