best practices for high availiblilty on lan
carl_townshend
Hi all
can anyone give me some best practices for setting up from access to dist layers on the lan, ie things I should set up for fast convergence, stp tuning, security etc ?
jedavis
Level 4
Level 4
Try this for high-level overview:
http://www.cisco.com/en/US/netsol/ns815/networking_solutions_program_home.html
And here are some best practices documents for the 4500 and 6500, though they is generic enough to apply to other platforms.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080094713.shtml
Look around CCO. There are a lot of good docs out there.
-Jeff
Go to www.cisco.com/go/srnd and then select Campus, Two design guides
HA recovery Analysis
Routed ACcess Design
Finally VSS design guide will there shortly.
The previous reply has good info too - but it more operational. Above design guide helps you in terms of architecture and design view point.
thx
Nimish
