08-23-2021 10:12 AM
What is the best method or procedures to keep the vlan database and settings on a switch, when moving to different vtp domain?
In addition, I will need to promote a new server from a client.
Should I perform the following in order:
1. change vtp to transparent
2. change to server
3. change vtp domain
4. update vtp password
Solved! Go to Solution.
08-23-2021 02:46 PM
Hello
Why would you want to save the old vtp information if the switch is joining a different vtp domain?
I would personally make the switch vtp transparent and then wipe the vlan database off that switch, bring it back as a client in the new vtp domain, let it get populated with the new vtp domain and then promote to vtp server.
If you do need to save it, then make a copy the vlan.dat file in flash before you perform the above.
08-23-2021 11:24 AM
I would say go transparent, then change domain and password, then change back to server.
08-23-2021 02:46 PM
Hello
